ST3 engine generator case same as ST4? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 29th, 2011, 4:50 pm   #1 (permalink)
rstick1's Avatar
Hi all,
I need the help of your collective experience.
I may have to replace the left-side generator case on a 2004 ST3. Looking at Ducati Omaha's part list, it is either part number 242.2.062.1A or 242.2.038.22B - both of which are no longer avail.
On eBay there is a ST4 generator cover which looks to my very untrained eye to be identical. The part number is 242.2.034.1A.
Are these the same? Would it fit?
Thanks in advance,
Ray
'07 999s Team USA
'04 ST3
rstick1 is offline   Reply With Quote
Old Jan 29th, 2011, 9:09 pm   #2 (permalink)
stryder's Avatar
What about another year ST3 alternator cover? The ST3 covers should all be the same 2004 - 2007. If you can find a parts diagram for a 916 engine you might be able to make a better evaluation of the ST4 cover, but from what I've seen of *996 ST4s* covers, they look the same as ST3 covers. If you buy it and it doesn't fit, you can resell it.
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
Old Jan 29th, 2011, 9:35 pm   #3 (permalink)
rstick1's Avatar
True - that's what I was thinking as well.
Everyone should get the desmotimes case saver to avoid your chain eating a hole in the case! I bought one too late.
'07 999s Team USA
'04 ST3
Old Jan 31st, 2011, 10:37 am   #4 (permalink)
Stick's Avatar
Ray,
You mention "eating a hole in the case". Do you think this was from running with your chain too loose? Or did your chain break, adn cause damage?
Stick
Present DUC: 2003 ST4S Yellow! 2001 ST2 Blue
Other brands (past):
1978 BMW R100RS Motosport, 1978 R100S, 1981 Moto Guzzi V50 Monza, and a long list of Hondasakizukis
Old Feb 1st, 2011, 1:36 pm   #5 (permalink)
rstick1's Avatar
Originally Posted by Stick View Post
Ray,
Definately from the chain too loose. Somehow my chain tensioner came completely loose and the left end of the swing arm self-destructed during the extra chain play.
I've just finished replacing the swing arm, chain and sprockets, and added a case saver for good measure.
I also ended up with a small hole on seam of the generator case. I've used the Ducati Threebond to fill it, and so far it seems to be holding fine.
Nice unexpected winter project.
'07 999s Team USA
'04 ST3
916 engine case same as 996? DucatiScotty Superbikes 3 Nov 20th, 2010 6:35 pm
250cc narrow case /350cc wide case engine brackets mike shannon Vintage 5 Apr 9th, 2010 5:10 pm
Need left side engine cover for my 996, not engine case crat996 Parts and Accessories 1 Feb 11th, 2010 1:49 am
Clutch and engine case sick50ford HyperMotard 4 Apr 24th, 2009 11:25 pm
New engine case bolts...where to buy? ZDM Superbikes 1 Nov 10th, 2008 7:58 pm
