Weight reduction in 2005 - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.comSportbikeTrackGear
Old Dec 25th, 2010, 7:06 am   #1 (permalink)
In 2005 the dry weight specs go down 24 lbs for all the ST models. In an earlier thread someone wisecracked that they just changed the way they rated them - does anyone know if this is a real reduction or not? If it is, what did they change that dropped the 24 lbs?
ptourin is offline   Reply With Quote
Old Dec 25th, 2010, 8:49 am   #2 (permalink)
Images: 14
ST3 Weight
A Better Cardio Program,lower the Carb intake(went to FI)and cleaner lines?
Mike S
PS
Merry Christmas
Mike S
1996 900SSCR
Tastefully modded.
Then Modded AGAIN!!!
2005 ST3.....sold
2003 ST4S W/ABS YES!!!
Secretary DucsUnlimited..find us on FaceBook!!
Ducoddy-SS is offline   Reply With Quote
Old Dec 25th, 2010, 10:09 am   #3 (permalink)
Moderator
SE84's Avatar
Images: 2
The changeover happened in 2004 with the redesign.
The lower weight is thanks to:
• CAN-line electronics which reduced the number of discrete wires to each device in the wiring harness
• Multifunction instrument cluster that weighs almost nothing compared to the mechanical gauges
• Removal of the mechanical speedometer drive
• Headlight assembly made from polycarbonate instead of glass
• Fewer support brackets to hold the nose assembly
• Integration of the external immobilizer into the dash unit
• Lighter upper triple assembly
• And I think the seat may be a tad lighter too
Merry Christmas
Current pastimes:
2007 Sport 1000 SE #84
2004 ST4s
SE84 is offline   Reply With Quote
Old Dec 25th, 2010, 10:58 am   #4 (permalink)
Chilehead
st2lemans's Avatar
Images: 95
Some is real, most is not.
Before, weight was with fluids and battery, but no fuel.
After, no fluids or battery (and no fuel).
Check the owners manual, it clearly states this.
Tom
P.S. Fluids and battery weigh about 9kg (20lbs).
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
st2lemans is offline   Reply With Quote
Old Dec 25th, 2010, 1:18 pm   #5 (permalink)
Weight reduction in 2005 [?]
Thanks for the replies. I'm still a bit confused by them - the specs I looked up show no weight changes in 2004 - they show lighter weights in 2005. So that doesn't sound like the 2004 remodel is what's being shown. Since they were 24# changes for all the models I was also wondering if there was some truth in thread I saw, that claimed it was all in the measuring methodology. I looked up the measurements below on several sites, and they all said they were measuring dry weight.
I put this out on the forum because I'm looking for an ST this coming year. I'm pretty small and light, so I'd consider hunting for a newer model if it was 24# lighter, but I wouldn't bother for a few # difference - and that'd make the hunt easier, more years to choose from.
Here are the specs I looked up:
(dry) ST3 ST3S ST4 ST4S ST4S/ABS
2003 215/474 212/467 217/478
2004 214/472 212/467 217/478
2005 203/448 201/443 206/454
2006 203/448 204/449
2007 201/443 204/449
Old Dec 25th, 2010, 1:21 pm   #6 (permalink)
Moderator
SE84's Avatar
Images: 2
The 2004 and 2005 bikes are identical except for the wet-clutch on the 2005. The redesign is what dropped the weight. I've had both a 2002 and 2004 ST4s, so I can speak from experience.
I'm embarking on a 50lb weight reduction program on my ST this spring. I'm curious if I can get under 400lb without the bags and with fluids.
Which brings up another question I have never checked into. I have always assumed that the dry weight quoted was without bags/brackets. Does anyone know?
Current pastimes:
2004 ST4s
Old Dec 25th, 2010, 1:47 pm   #7 (permalink)
DeBenGuzzi's Avatar
I'll never understand this, weight should be with full up fluids and battery, when do you ride without them???
"Boy, those Italians, they have a different word for everything"
Rides-
00' Guzzi V11 Sport, (sold)
07.5 Aprilia RSVR, (totaled)
98 Ducati ST2
DeBenGuzzi is offline   Reply With Quote
Old Dec 25th, 2010, 2:57 pm   #8 (permalink)
Pablo Pirate's Avatar
Images: 9
Merry Christmas!
What is the weight of an ST3? Wet or dry?
You wanna stick that ST3 in a Superlight!!!!!
Under 175kg Full Wet and 115Bhp (Soon to be more) at the rear with 77lb of torque!!!
Pablo
Pablo Pirate is offline   Reply With Quote
Old Dec 25th, 2010, 10:53 pm   #9 (permalink)
Looked these up in Motorcycle consumer news
date of test model WET weight
12/97 ST2 520#
12/98 ST4 524#
10/05 ST3 518#
8/04 ST4s 531#
All fluids, ready to ride. Hope this help some. Dave
tisisit is offline   Reply With Quote
Old Dec 26th, 2010, 4:05 am   #10 (permalink)
Chilehead
st2lemans's Avatar
Images: 95
Without fuel and bags (but with the brackets), mine is down to 440 lbs after dropping 45lbs weight. Not cheap, and even less cheap to remove more weight.
Tom
1985 LeMans
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
Weight Reduction Gow Supersport 62 Dec 8th, 2010 5:42 pm
weight reduction jiggyfly Supersport 20 Aug 25th, 2010 9:50 pm
Weight Reduction NYSport HyperMotard 9 Jun 5th, 2010 8:50 pm
Flywheel weight reduction program dietrichpfeifer Sport Classic 32 Jun 8th, 2008 11:07 am
Weight reduction kever888 Sport Touring 23 May 11th, 2006 8:20 am
