Dec 23rd, 2010, 4:13 pm
ST2 Battery Charge
Hey Guys- typical winter time battery blues. Is there a way to charge the battery (non- trickle charger) without taking the right side fairing apart? What about that Auxillary plug under the seat? Does it go "both ways"? Thanks, Jim
2002 ST2 -Yellow
2006 999 (Black & awesome!)
Dec 23rd, 2010, 5:05 pm
I assume the ST2 is the same as the ST3. I only use the Auxiliary plug to charge my battery. It's great if the battery is low and you need an overnight charge. It is a fused outlet direct to the battery.
David
Ducati rider since '74
1966 250 Mark3
2004 ST3
Dec 23rd, 2010, 5:53 pm
I use the Aux plug to charge mine too.
Dec 25th, 2010, 4:09 pm
Thanks guys. Dumb question. How do you determine which terminal you plug POS & NEG into? Thanks- Merry Christmas.
2002 ST2 -Yellow
Dec 25th, 2010, 5:57 pm
Ducati Designs
Center pin is positive (+12V)
pg
DD
Dec 25th, 2010, 6:10 pm
Dumb question.
Not dumb at all Jim. If you dont ask and you haven't read it somewhere, then you wont possibly know.
I had no idea that the Aux plug could be used for such a purpose, until I read it somewhere on a (probably this) forum.
I mean it's hardly obvious really is it - I would have been the last person on Earth to assume that a power outlet, was also a power inlet for battery charging purposes...
Merry Christmas.
Thanks Jim, and the very same to you mate.
Dec 25th, 2010, 6:33 pm
Thanks Mark. Is there an adapter for the male side that I can hook my charger clamps onto? Thanks, Jim
2002 ST2 -Yellow
Dec 25th, 2010, 6:53 pm
DucJim, check out the Powerlet website...they have the male plugs plus many other goodies too! Do your clamps unplug from the charger? If so, they probably have an adapter that will plug right into your charger.
Plugs Sockets Wire & More - Powerlet Products
Good luck!
Mike
2006 ST3
2004 KLR 650 (the Truck)
Dec 25th, 2010, 10:55 pm
Thanks Mike. No, my charger is a standard car charger. Just alligator clamps hardwired to the charger. Jim
2002 ST2 -Yellow
