Dec 5th, 2010, 1:16 am
Can an ST2 be bored & stroked?
Just wondering if an ST2 944 engine be bored & stroked?
If it can, what to?
Cheers
Craig
2004 998S FE
Dec 5th, 2010, 2:02 am
Get an ST4s
Got a bit more go
Got the suspension
Got the bigger back wheel
1098 SBK 2008 stealth black - - - - - - - - - Multistrada 1200 2010 White
Dec 5th, 2010, 2:09 am
Originally Posted by Able Duc
Get an ST4s
Got a bit more go
Got the suspension
I knew you would be the first to respond.
I like my 2 valver, I just want to see if anyone has hot rodded their 944
I also wondered could you slip in a 1098 or 1198 engine into our ST frames, you probably can't, but wouldn't it be cool if you could!
Craig
2004 998S FE
Dec 5th, 2010, 2:51 am
Probably could do a 10/1198, might need to eliminate or change the croos tube above the engine, and change the swingarm. Most likely need to add extensions to the rear frame engine mount, to provide addional stability to the swingarm pivot pin. To narrow bearing area on the SBK engines, I imagine.
Dec 5th, 2010, 2:56 am
yeah too hard
Dec 5th, 2010, 2:57 am
Hi Dan,
Why do you need to change the swing arm?
Craig
2004 998S FE
Dec 5th, 2010, 3:01 am
Originally Posted by cb4265
Hi Dan,
Craig
cause it bolts onto the motor
the chances of your swingarm bolting straight onto an 1198 is zero
Dec 5th, 2010, 3:08 am
Right then, back to my original question.
Craig
2004 998S FE
Dec 5th, 2010, 4:26 am
Chilehead
Craig
I have stock bore and stroke, but head mods and hi-comps, and have 90BHP at the rear wheel.
I also dumped 20kg in weight off the bike.
Tom
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
Dec 5th, 2010, 7:02 am
Moderator
Tom
I think that Tom's upgrades are the best way to get more power out of an St2. The heads and valves are can't take advantage of bigger pistons/ more volume.
And I know what you mean about the 2V. I really like my ST2, no desire to have a 4/ 4s.
2001 ST2
1998 SuperSport
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Got bored...
94CobraR |
Photography |
3 |
May 9th, 2009 10:07 am |
Bored
vanslam |
2003-2009 1st Generation Air-Cooled |
1 |
Sep 25th, 2008 9:59 pm |
