Just in need of confirmation-Paso rear suspension adjustments - Ducati.ms - The Ultimate Ducati Forum
post #1 of 3 (permalink) Old Feb 11th, 2015, 2:00 pm Thread Starter
Red face Just in need of confirmation-Paso rear suspension adjustments
Hi all, having done my tiny bit for ST manuals I am attempting the same for the Paso-750-907 range. The 750 Paso manual seems incorrect to my 20 years ago memory. I have attached the original manual's content about adjusting the rear shock. Are my thoughts at the start correct or am I more senile than I thought?
I know about the Paso sub forum but it is very quiet compared to this one and the Paso was a belt drive Sport-Tourer [They said!]
Cheers Rik
Too many Brit Irons to mention.
Couple of soul-less Rice Burners.
1980 Darmah SD Very sadly missed due to marriage
1987 Paso 750 Destroyed my spine I think
1998 ST2 Blissful answer to Divorce and rather late mid-life crisis
Unclebeastly is offline
post #2 of 3 (permalink) Old Feb 11th, 2015, 2:31 pm
Nobody
Chuckracer's Avatar
Images: 2
Both shocks have a remote preload adjuster (pre-charge). Your only other adjustment is rebound damping (brake in the extension).
I don't know why the shock w/ the two-ring preload would also have a remote preload adjuster on it. Maybe the rings were to ball-park the preload, the fine tune it (or make ajutstments for passenger/luggage) with the remote?
Either way, it wouldn't be for compression adjustment.
KTM950SMR
Chuckracer is offline
post #3 of 3 (permalink) Old Feb 11th, 2015, 3:45 pm Thread Starter
Thanks Chuckracer, that makes sense now. I think, way back in the 90's, I squidged the preload using the rings because I'm fat but all I got was back pain even with the precharge knob backed right off! I'll leave the advice as it was Rik
Human Verification
Kit to add adjustments to 821 base suspension? Fr333zy HyperMotard 7 Sep 17th, 2013 9:57 am
Suspension Adjustments for ST4 samman23 Sport Touring 3 Jun 30th, 2007 11:25 am
2-up suspension adjustments 900SSKen Supersport 12 Apr 10th, 2007 1:31 am
Ducati 748 Suspension Adjustments lucaboi Superbikes 4 Mar 26th, 2007 11:34 am
xx9 suspension adjustments 749ebc Superbikes 7 Nov 11th, 2006 6:41 am
