88 750 paso dual mikunis - Ducati.ms - The Ultimate Ducati Forum
post #1 of 3 (permalink) Old Jul 17th, 2007, 7:09 pm Thread Starter
I recently purchased dual mikunis from a race shop that specializes in ducati rebuilds, installed carbs and bike runs/idles fine but breaks up bad after 4k rpm, shop says they may be overjetted as carbs were used only for bench testing race engines. carbs look brand new. and were spotless inside. my bike is stock except for yoshi slip ons. Stock weber basically ran bad all the time but did not break up that bad at high rpm. Any suggestions? carb does not seem to have adjustments other than choke and idle/throttlethere are rubber boots on top of carbs which may hold mix screws, but impossible to reach with tank on.
Thank you for any help.
Eric.
bluepaso is offline
post #2 of 3 (permalink) Old Jul 17th, 2007, 7:42 pm
Stick's Avatar
You should be able to drop the float bowls, and remove the main jets. They're the larges, lowest ones in the float bowl. And there are sizes stamped into ea. jet. Not sure what size you'll acually end up with, but if you find something like a 160 or 180 in there, it's most likely too big.
Try asking the same ??? in the vintage section. And I think there are other forums that are Paso-centric.
Stick Need an adrenaline rush? Shove a DUC between your legs.
Present DUCs: 2003 ST4S, 2001 ST2, 1996 900 SS/CR
Stick is offline
post #3 of 3 (permalink) Old Jul 18th, 2007, 7:31 am
Desmo_Demon's Avatar
I can't help you, as I've got Dellortos on my Paso, and the jets should be as easy to change out as Stick mentioned. You may also want to post about this on the www.ducatipaso.org forum. There are a couple of guys that have Mikunis on thier bikes.
IBA #32735
Desmo_Demon is offline
Human Verification
Dual plug heads gorma900 Supersport 9 Apr 15th, 2013 5:36 am
Paso Poster Dutch900 Paso 1 Jun 20th, 2007 11:44 am
Extended my riding season w/ Dual Star Heated Grips sydpok Sport Classic 3 Jan 4th, 2007 1:32 pm
Cant find a manual for a paso 906 can you help ? decesaro Paso 3 Oct 10th, 2006 3:52 pm
