Nov 16th, 2006, 9:22 am
I'm too old for this....
IE7 issues
After a month now of going crazy, I gotta bring it up.
Internet Explorer 7 pops up an error message on every forum in this site due to the use of
window.preblinkonload();
that isn't supported anymore (security)
Hope you can fix it cuz it's driving me nuts!
(I have the javascript debugger turned on since my work is as a web developer, but this was not an issue with IE6)
 Peter S
_______
1996 900SS/SP/SL
Carbon DP body, Carbon Monoposto SL rear, FBF Carbon high pipes, Carbon everything else,
Corbin seat,Wilbers doubleClicker shock, Pilot Power 2CTs, Alth wavy rotors front and rear,
4-piston 4-pad calipers, Radial MCs, 996S TiN forks, Cyclecat triple clamp, rearsets & clipons,999 switchgear,
1996SL decals, custom paint...
Nov 16th, 2006, 11:06 am
Administrator
I am using IE7 on three computers, work, home and laptop with no issues. I can suggest to delete your cookies and temp files and then see what happens for a starting point. If you still have the issue I guess the only other two suggestions I can make is turn off the debugger or use Firefox.
Scott
Sacramento CA
HDDC Posse
'05 BMW LT-C Ocean Blue
'03 Ducati ST4S with ABS
'08 BMW F800ST (Jessica's)
Some of the most asinine things people do are typically preceded by the two words "Watch this."
Nov 16th, 2006, 12:16 pm
Well, I was just wondering how important whatever it's doing is.
Firefox gets the same error if you turn it's errorchecking on too.
So preblinkonload() is failing in FireFox and in Explorer7. Just because the browser isn't telling you it's failing doesn't mean it works...
Want me to fix it? I charge 80$ an hour (special price just for you  )
no worries, I guess it's just because I'm the cross-platform guy here at work..
 Peter S
_______
1996 900SS/SP/SL
Nov 16th, 2006, 2:17 pm
Lifetime Premium
No problems for me with IE7. FF 2.0 gave me problems with lots of sites, so I'm back to Microsoft.
Tony
Nov 16th, 2006, 2:29 pm
You don't SEE the problems if you don't turn the script debugging on. You wouldn't normally run with the debugger turned on either, you'll likely get either no indication of error or the occasional little yellow error triangle in your status bar (bottom left) I have to run with the debugger for my work.
I brought this up only because the preblinkonload() method is so obscure (google it, you'll see. Rarely do you get anything with only 5 results) and was wondering if it did anything useful at all. If it does, well it's not happening in FF or IE7.
 Peter S
_______
1996 900SS/SP/SL
