Clutch fluid getting dark? - Page 2 - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > Ducati Motorcycle Forums > Multistrada > 2010 - Current 2nd Generation Watercooled
Motorcycle.com
Old Aug 12th, 2010, 1:58 pm   #11 (permalink)
Shazaam's Avatar
I have also found that Valvoline SynPower Dot 3/4 hydraulic fluid - Part No. 057 (boiling points: dry 513ºF, wet 333ºF) stays clear in my clutch reservoir.
Old Aug 12th, 2010, 8:09 pm   #12 (permalink)
MultiModerator
vduc's Avatar
Images: 72
My favorite brake fluids are Motul RBF600 Synthetic DOT 4, dry boiling point of 593°F (312°c) and wet boiling point 420°F (216°c), all I would use in my track bikes and Motorex DOT-5.1. Most important use brake fluid from a new sealed container to minimize moisture and contaminants.
Vito
93 750SS - 10 Hypermotard EVO SP - 12 Streetfighter S - 04 aprilia RSV1000 Factory
vduc is offline   Reply With Quote
Old Aug 15th, 2010, 2:21 am   #13 (permalink)
Its definately nothing to do with humidity. I live in the far north of England and my fluids black as fucking coal.
(maybe its due to all the rain we get)
Bengaz is offline   Reply With Quote
Old Aug 15th, 2010, 1:19 pm   #14 (permalink)
It's not just the bike...my Tri is a bit darker as well.
Buckeye is offline   Reply With Quote
Old Oct 10th, 2011, 7:36 pm   #15 (permalink)
Toruk Makto's Avatar
I bought mts 2011 and after first 800 miles, the clutch and rear break fluids are black. This is not usual as I did not have this issue in the past. I found this topic with the same problem as mine however i could not find any solution to solve these problem. Your comments would be greatly received.
Thanks
Toruk Makto is offline   Reply With Quote
Old Oct 10th, 2011, 9:56 pm   #16 (permalink)
Turkishexpress's Avatar
fap fap fap
2011 Multistrada S Touring
K7 GSX-R 600 - Track Only
Turkishexpress is offline   Reply With Quote
Old Oct 10th, 2011, 11:46 pm   #17 (permalink)
Images: 2
My local independant level 2 Ducati tech caught me stopped at the Post Office the other day. First thing he said to me was..."change that dark clutch fluid". He didn't say why it turned dark but that he thought it was bad business. I went home and replaced the 10 month old fluid with new. I think some of the blackening comes off the black rubber seal inside the reservoir. My clutch fluid always goes black first, with little or no blackening of the brake fluid. Hum?
Brushpuppy is offline   Reply With Quote
Old Oct 11th, 2011, 4:34 am   #18 (permalink)
Had the same thing happen on my Aprilia - believe it was the slave seal. The seal failed at 17,000 miles - then new seal with new fluid and within a few hundred miles it was black. Never impacted clutch performance, black or clean.
falcodave is offline   Reply With Quote
Old Oct 11th, 2011, 6:31 am   #19 (permalink)
My friend also own a MTS 1200 - 2011, bought in Sep, he also has the same issue. The front break fluid is Ok. We are wonder why? It did not happen to my previous bikes Suzuki gsx600, Honda CB 1000r.
I changed the fluid twice but it happens again after 600 to 800 miles.
Old Oct 11th, 2011, 9:25 am   #20 (permalink)
For some reason I'm having this sudden urge to head off to Japan...
whistle is offline   Reply With Quote
Dark clutch fluid… poolagent Sport Classic 26 Mar 27th, 2011 4:55 pm
clutch and rear brake fluid dark hyperdookie HyperMotard 6 Apr 6th, 2008 12:10 pm
Clutch fluid DJMPowersports Superbikes 12 Oct 16th, 2007 2:17 pm
Changed clutch fluid now clutch seems to slip migrane Superbikes 2 Mar 29th, 2007 5:01 pm
Clutch fluid. RichieW Supersport 15 Oct 12th, 2006 10:19 pm
