Aug 14th, 2011, 6:51 pm
Closed/Open Loop...
Someone who has installed the full termi system, does the replacement DP ECU keep the bike in open loop mode through the throttle/rev range like the 1098 DP ECU? Or is it like the Streetfighter DP ecu where the bike still remains closed loop and a power commander can't be used in the low range?
thanks for the info!
Aug 14th, 2011, 10:13 pm
I think it still keeps it in closed loop mode because it retains the sensors,otherwise i dont think it would still need the sensors.Im guessing it is open loop at idle and close to full throttle and closed loop in the cruise range.
Aug 15th, 2011, 6:44 am
It is still closed. But the Redline powercommander has a way of tricking the bike and does allow adjustments across the full rpm range.
Aug 16th, 2011, 3:47 pm
Thanks. Would be interested to know how redline 'tricked' it...
Sep 16th, 2011, 6:22 pm
The race ecu for the diavel and mts1200 does retain the sensors. We have just yesterday worked out how to disable the the o2 sensors by changing bytes inside the ecu code (just like the dp ecu does on older models) Its the best fix by far because eliminators are not needed.
www.cjsracing.co.uk
cylinderhead porting/reworking/crank balancing/engine blueprinting/dyno tuning/custom ecu reprogramming/o2 removal/ecu developments .
www.hypertrick.net
Customised dyno fuel maps/mapping/and a whole load of other cool reports.
Sep 28th, 2011, 11:00 am
With an $ 89.00 plug that you plug into your bike and you are all set and have open loop.
Sep 28th, 2011, 11:59 am
Which plug would that be? FAT DUC?
2013 1199R
2012 1199S (sold to my riding buddy)
2012 Diavel Carbon Red (traded in for the 1199R)
2011 MTS1200S (sold)
2009 Hayabusa (sold)
2005 GSXR750 (sold)
2008 Hayabusa (totaled)
2007 Vstar 1300 (collecting dust)
Sep 28th, 2011, 12:03 pm
No, a sensor that Redline makes for the Diavel and Multistrada 1200 to make it open loop.
If you need one let me know.
Sep 28th, 2011, 12:13 pm
I wasn't aware that Redline had sensors for the Diavel and the MTS1200.
I just bought 2 sets of Fat Duc for my Diavel and MTS1200 a few days ago. Haven't received them yet. Since both of them are Termis with race ECU, I was told that they are different than the standard Fat Duc. Two "plug-ins" are required for each bike... one for each O2 sensors.
How do the Redline ones work?
2013 1199R
2005 GSXR750 (sold)
Sep 28th, 2011, 3:32 pm
Single plug in, have it on my bike since day one.
Redline tells me that it makes the bike richer down low and makes it much smoother running.
