This quick-turn gas cap, made by Accossato, is beautifully engineered to be extremely light and simple to use. There is no need to fuss with keys or tools to put fuel in your bike. If you’re looking for a trick gas cap that weighs about a quarter of the OEM fuel filler cap, look no further than this!
We have Accossato Carbon Fiber quick turn gas caps ready to ship for the following Ducati models:
748/916/996
848/1098/1198
Availability is
very limited on this carbon fiber gas cap fixture. To order yours, call Mike at 866.931.6644 ext 804.
Every Accossato quick-release gas cap is supplied with a carbon fiber surround, a precision machined twist locking plug and all required installation hardware.
The gas cap’s plug is held securely in place with a cam mechanism that is slotted to lock the hardened stainless steel pin in place. To open, push down on the spring-loaded mechanism and twist.
Real carbon fiber is used to reduce weight while a high-quality O-ring prevents leakage.
