Now you don’t have to sacrifice your bike’s grips just to have warm hands with Heat Demons grip heaters! That’s because these install
inside your bike’s handlebars, delivering four user-adjustable levels of heat to the grips and keeping your hands warm as you ride. Everything is controlled by a LED-illuminated switch that’s designed to be mounted on the handlebar in place of the bracket for the clutch or brake perch on many motorcycles, but it can also be mounted separately. The system draws power from your bike’s 12V supply to provide consistent, even heating that’s monitored by a thermister for a comfortable grip even when it’s cold outside. Other than the dimmable LED control module, it’s unlikely anyone will notice your bike has heated grips. These are perfect not just for the late-season rider, but anyone that often rides at night when the weather gets a little cooler. All that’s required from your motorcycle is hollow handlebars and a 12V power supply.
Heat Demons grip heaters are not yet available on our website. To order a set, call TJ at 866.931.6644 ext 817. You can also email us with any questions you have – send those to FORUM at RIDERSDISCOUNT dot COM with MOTORCYCLE GRIP HEATERS in the subject line and we’ll get back to you right away.
Clear, step-by-step instructions are included with every Heat Demons universal mounting kit. There’s even a template to help you drill the hole to run the wires to the control switch.
Each heat element installs within your motorcycle’s handlebar. In this way, you can use whatever grips you want! No more generic-looking grips required to keep your hands warm.
One button controls a combined total of 40W of heat energy. All Heat Demons grip heater kits are made in the USA!
Dimmable LED lamp allows you to easily see how what setting the heaters are on. Control switch is available in either a black or chrome housing.
