Zero Gravity became well known back in the 90’s with the introduction of the now ubiquitous double-bubble windscreen design. Originally developed for racebikes, the “bubble on bubble” shape has been the single most-copied aspect of their products ever since. All Zero Gravity windscreens are manufactured from acrylic plastic using a blow-molding process that creates a final product which allows light to pass through without bending it and distorting your view of the road ahead. For easy installation, windscreens are drilled at the factory to fit OEM mounting points – simply re-use your OEM hardware for installation.
We have four different versions of Zero Gravity windscreens available:
SR Series Windscreens retain the shape of the OEM piece while providing a clearer view of the road ahead. Often times, they weigh less than stock too.
Double Bubble Windscreens feature the “bubble on bubble” design that made Zero Gravity famous. The extra wedge-shaped bubble in the middle portion of the windscreen provides more wind protection and better aerodynamics, especially when the rider is tucked in for speed.
Corsa Windscreens are the latest offering from Zero Gravity. These were specifically designed to increase top speed by providing extra wind protection while tucked in and they’re also an excellent choice for taller riders. These are only available for latest generation of sport bikes.
Sport Touring Windscreens are designed for the rider that is most concerned about real-world comfort. These windscreens are the tallest of the Zero Gravity line and are designed to provide the greatest amount of wind protection in the upright riding position.
Zero Gravity windscreens are not yet available on our website. To order yours, call MIKE at 866.931.6644 ext 804. You can also email us with any questions you may have – send those for FORUM at RIDERSDISCOUNT dot COM with ZERO G in the subject line and please specify the type of motorcycle windscreen you want and the model/year of the bike you’re riding for accurate availability and fast shipping.
Almost all Zero Gravity windscreens are available in clear, light smoke and dark smoke tints. Notice that all holes are pre-drilled in the OEM mounting positions for easy installation. We also have available extra hardware kits with rubber expansion grommets to replace any worn-out items you may have.
Ducati 848/1098/1198 with Zero Gravity Windscreens.
