Don’t bother fumbling with keys, the garage door opener that’s in your pocket (which might not work if it’s been raining) or otherwise have to jump off your bike just to operate the garage door with the Flash2Pass Remote Garage Door Opening System. This two piece kit comes with everything you need to install a convenient garage door remote system on your bike that operates with two flashes of the high beam. You’ll never have to worry about batteries again either because it draws energy from the power supply that’s on your motorcycle, scooter or ATV. You can even use it on your car, snowmobile – really anything that runs on 12V. Up to six remotes can be programmed to work with one receiver.
The receiver itself can be used to replace the button in your garage or piggyback on the one you already have installed so, you don’t need to replace the remotes for all of your vehicles unless you want to. The lightweight transmitter itself taps into the high beam circuit of your ride with the included Posi-Tap connectors making two flashes of the brights all it takes to open or close your garage.
Get yours for $68 with free shipping anywhere in the lower 48 states by giving MIKE a call at 866.931.6644 ext 810. He'll send you this system in no time. If you prefer, you may send your inquiries to FORUM at RIDERSDISCOUNT dot COM with FLASH 2 PASS in the subject line. Also, should you want to equip more than one vehicle with a high-beam operated opener, additional remotes can be had for $31 each – which is less than name brand garage door openers you find at Home Depot!
The complete system as it comes out of the box. Compatible with just about any garage door opener system built after 1982.
This receiver/garage door button wouldn’t look out of place in the garage.
Remote weather-proofing is clear from this angle. Up to six remotes can be used with one receiver with a simple one-step programming procedure.
