Until recently, if you wanted riding shoes that offered a decent level of protection yet still provided a comfortable platform to walk around in, you were out of luck since these two features were almost always mutually exclusive. Now, with the Alpinestars Mille Riding Shoes, you can get meaningful foot protection that’s also very comfortable. An oiled suede outer sits atop a leather chassis which keeps water out while the mesh-lined innards keep your foot from sweating in all but the worst conditions. PU-reinforcements on the outside of the toebox and on the heel keep tabs on the areas most often affected in the event of a crash. Alpinestars Tech cleverly integrated shift pads over the toes on each foot for extended durability and to prevent pressure points when manipulating foot controls. The sole is grippy, flexible and soft without being too pliable so as to wear out quickly.
Available in black only in US sizes 6-14, call MIKE at 866.931.6644 ext 804 to get a pair sent your way. You can also email him – FORUM at RIDERSDISCOUNT dot COM with ASTARS MILLE SHOES and be sure to indicate exactly what size you want and we’ll get back to you right away.
Reinforced shift pads on both feet.
Speed lace mechanism allows quick in and out operation and, combined with a Velcro upper tab, allows one to quickly tuck away the excess lace so it won’t get caught up in any moving parts.
