Alpinestars Tech Heated Gloves - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Motorcycle.com
Old Jan 19th, 2012, 12:23 pm   #1 (permalink)
Official Platinum Sponsor
RidersDiscount's Avatar
Anyone who's ridden in less than favorable conditions knows how much of a damper cold, wet hands can put on a ride. Alpinestars has the answer to both of these problems with the introduction of their new Tech Heated gloves. These gloves feature a high quality construction, waterproof/breathable Drystar membrane, and a quick, easy connection to any bike that make them a great addition to anyones touring set-up.
The Alpinestars Tech Heated gloves use a leather construction with textile, suede and polyurethane inserts for a high level of protection. In addition to the durable main leather construction, the gloves feature PU inserts in the sides, along the wrist, and PU armor molded across the knuckles. There is also extra padding along the top of all fingers. Rounding out the list of safety features is the Alpinestars patented finger-bridge connecting the 3rd and 4th fingers. These safety standards are similar to those you would expect to find on a top of the line pair of racing gloves.
For weatherproofing, Alpinestars makes use of its Drystar membrane, which is both waterproof and breathable. This allows it to maintain heat while wicking away any sweat that would normally build up, leaving you with dry, comfortable hands. Heating is accomplished with a new active heating technology that heats up the gloves quickly and provides consistant heat over the entire hand.
We tested the heating capabilities of these gloves in the shop by hooking the wiring loom up to one of our Ballistic Lithium Ion batteries. The gloves were up to temp in only 3 - 4 minutes and we measured a maximum internal temperature of 107° F with our infrared thermometer.
The gloves come with a long, split-y cable, but in order for these to work with your bike you’ll need to order the controller kit as well. This controller kit comes with the battery wiring loom, on/off switch, short splitter and extension cable, meaning that these are very versatile and will work for just about any application.
These gloves are exactly what you need if you plan on doing any riding in colder climates and will work independently, or in conjunction with the Alpinestars Tech Heated vest (soon to be featured in another review). We found sizing to run small, similar to GP-Pro or GP-Tech gloves so we recommend you order the next size up from your standard glove size.
These aren't listed on our website yet, so call John at 866.931.6644 ext 812 or shoot us a PM if you are interested. You can also feel free to send a note to FORUM at RIDERSDISCOUNT dot COM with ALPINESTARS TECH HEATED GLOVES in the subject line and we’ll get back to you right away.
The Tech Heated gloves feature the Alpinestars finger-bridge and molded PU knuckle protectors.
Accordion stretch panels along top of hand and the first two fingers for comfort and flexibility.
The cuff features double layer construction to avoid thermal bridges and a storm gauntlet to fit over jacket sleeves and keep the elements out.
Battery wiring loom with inline fuse (37”), extension cable (24”) and long Y split harness (94”) allow you to route the connection points wherever you prefer on your bike.
Ask me about our specials!
Alpinestars GP Tech Gloves XL Dink Gear 2 Dec 11th, 2011 8:43 pm
Alpinestars Tech 1-R Race Suit & Tech 1-R Leather Jacket Review RevZilla RevZilla.com 0 Oct 20th, 2010 9:05 am
Alpinestars GP Tech Leather Gloves RidersDiscount Riders Discount 3 Apr 22nd, 2010 8:00 pm
Heated grips or gloves? vonotto Sport Touring 26 Dec 29th, 2007 11:40 pm
