X-Arc LED Rear Turn Signals - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.comMotorcycle.com Classifieds!
Old Nov 18th, 2011, 9:57 am   #1 (permalink)
Official Platinum Sponsor
RidersDiscount's Avatar
X-Arc Turn Signals are the latest aftermarket turn signals from High Tech Speed, the makers of Proton turn signals. The Massachusetts-based company designs and builds the X-Arc turn signals in the USA right at their Groveland facility. These turn signals employ newer high-flux LED elements that are brighter than conventional LED elements for turn signals that produce over 300 lumens of light. That’s the kind of brightness that will easily get the attention of other drivers! But, the best part of all is that these rear turn signals are small – measuring 21mm in diameter on a hull that’s 38mm long! The 15mm stalk through which the electrical wires run is completely removable so no matter what you’re riding, these motorcycle turn signals won’t break up the lines of even the cleanest custom ride.
CNC-machined from billet aluminum, each turn signal has a two-year manufacturer’s warranty and include an onboard microprocessor that allows them to flash at a normal rate without the need for any extra equipment. Three different light function styles are available:
X-Arc Red - dual intensity for running light and brake light
X-Arc Yellow - dual intensity for running light and turn signals
X-Arc Duo - Dual intensity red, plus yellow for full-function running light, brake light, and turn signal
We’ve sold many turn signals from High Tech Speed and have had nothing but excellent feedback from our customers because they’re durable, very bright and easy to see. Get a set for your motorcycle by calling Mike at 866.931.6644 ext 804 or, you can send him an email – FORUM at RIDERSDISCOUNT dot COM is the address with X-ARC TURN SIGNALS in the subject line and please be sure to specify the X-Arc Funciton / chassis color combination you want and we’ll get back to you right away.
X-Arc turn signals in satin black.
The X-Arc’s aluminum stalk can be removed for flush-mount applications.
Small, yet very, very bright.
Ask me about our specials!
1098 Rear Turn Signals scot Superbikes 2 May 1st, 2012 9:33 pm
WTB: Rear Turn Signals Chuckracer Parts and Accessories 2 Feb 28th, 2010 4:44 pm
ST-2 rear turn signals Twisty1 Sport Touring 1 Jan 2nd, 2008 9:54 pm
DP rear LED turn signals Hypermotard1 HyperMotard 8 Oct 28th, 2007 1:26 am
Rear Turn Signals Ducati23 Sport Touring 11 May 18th, 2007 7:46 pm
