CRG Supersport Clutch Lever Kits - Ducati.ms - The Ultimate Ducati Forum
Old Nov 7th, 2011, 10:15 am   #1 (permalink)
Official Platinum Sponsor
RidersDiscount's Avatar
The Supersport clutch lever kit from CRG is not your average clutch perch, but rather a simple high-quality replacement for your OEM clutch perch and lever. Its dual 16mm bearings provide a seamless lever feel that can help you improve your green flag / green light performance off the line. As with all CRG levers, length of reach is adjustable via a large red adjuster rheostat located near the lever’s pivot joint. Clutch play can easily be adjusted via the same kind of index knob found on most OEM perches. Dialing in the right feel is made possible with an adjustable clutch lever ratio function which can be set in one of three positions to suit almost any rider’s taste. Plus, you probably won’t have to modify your motorcycle’s wiring as these kits accept the installation of OEM clutch safety switches for most late model Yamahas, Hondas & Suzukis.
Just like all other CRG parts and accessories, CRG Supersport clutch lever kits are precision machined from 6061-T6 aluminum and tumble-polished for a smooth, snag-free finish.
Available in gray (shown), black or gold finishes with either shorty or standard length levers, call Mike at 866-931-6644 ext 804 to order. You can also send an email to FORUM at RIDERSDISCOUNT dot COM with the subject line CRG SUPERSPORT CLUTCH KIT in the subject line - be sure to specify what color and length you want and we’ll get back to you right away.
The Supersport Clutch lever kit.
Built with CRG’s proven adjustment mechanism for a perfect reach to the clutch lever.
Simple adjustable receiver for varying lever ratio. Notice the brass plate, which allows the installation of the OEM clutch safety switch.
High-quality stainless steel hardware is fitted as standard.
A simple universal installation fits all late-model sportbikes with 7/8” diameter bars.
Ask me about our specials!
Any recommendations for aftermarket clutch lever, shift lever? awarrioralways Multistrada 43 Sep 2nd, 2011 11:54 pm
Break lever/clutch lever adjustment JohnE1000 Supersport 8 Apr 1st, 2009 8:29 pm
looking for used parts: clip ons, clutch lever, shift lever zunk1 Sport Classic 5 Mar 21st, 2009 10:52 am
clutch kits Mars Superbikes 12 Mar 28th, 2008 9:56 pm
ProCutting clutch kits... mad Ducati Motorcycle Chat 4 Jan 20th, 2007 8:09 pm
