DMP PowerGrid Integrated LED Tail Light Kit - Ducati.ms - The Ultimate Ducati Forum
Old Nov 1st, 2011, 1:30 pm   #1 (permalink)
Official Platinum Sponsor
RidersDiscount's Avatar
With a brake light and turn signal flasher all built into one design, Dynamic Moto Power Powergrid integrated LED taillights have the kind of brightness that will get you noticed! What sets DMP Powergrid kits apart from other aftermarket integrated taillights is their lens designs which are specifically tailored to reflected the most light possible outwards via a mirrored LED surface finish. That, and the high-quality polycarbonate lens housing features a topography that further enhances light output so other road users are better able to see you. The wire harness employs a factory-type brake light connector and you simply need to re-use the OEM hardware for installing a DMP taillight kit. You’ll be able to eliminate your OEM turn signals too so you can easily clean up the rear end of your bike.
To assure proper functionality, all DMP light kits are tested at the factory, twice: once during production and again before final packaging. Easy-to-understand installation instructions are also included with each kit.
Kits are available with either smoked or clear lenses for the following Ducati Superbikes:
848
1098
1198
DMP light kits are not yet available on our website, for more information, call Mike at 866.931.6644 x 804 or send a note to FORUM at RIDERSDISCOUNT dot COM with DMP POWERGRID DUCATI INTEGRATED TAILLIGHT in the subject line, include the model/year of the bike you own and whether you want a clear or smoked lens and we’ll get back to you right away.
DMP Powergrid integrated lights combine the brake like and turn signal functions into one clean design that follows the OEM shape perfectly.
A powerful grid (Powergrid) of light emitting diodes are arrayed in a manner that compliments the specially-shaped polycarbonate lens housing for a brilliant display that will get you noticed by others on the road.
Ask me about our specials!
Best integrated tail light morvegil StreetFighter 3 May 10th, 2011 5:51 pm
FS: (MA) 848/1098/1198 CA Smoked Integrated tail light & Versa-Light duey Parts and Accessories 2 Sep 20th, 2010 11:09 am
Integrated tail light gnance Superbikes 9 Apr 1st, 2009 2:17 pm
Integrated Tail Light majbuzz Supersport 51 Aug 2nd, 2007 5:41 pm
