A staple in motorcycle paddocks around the globe,
Alpinestars Supertech R boots offer a level of protection that is unrivaled and do it all in an incredibly comfortable manner. As such, Alpinestars saw it fit to slightly refine, rather than completely redesign, the Supertech R boots and also added some new colors too.
Alpinestars Supertech R motorcycle boots use a two-piece design comprised of an outer shell and a separate, removable inner bootie. These two pieces work together to put your foot in a vault that’s surprisingly flexible, allowing the user to walk in a natural gait and control the bike with a reassuring feel, all without sacrificing safety in terms of crash protection. The exterior shell bristles with armor to protect the heel and the upper shin/calve areas from impact. Below this, a durable sole allows you to flex at the ball of your foot while being very rigid in front of and behind this point. The toebox is rigid and it is covered at one side by a molded shifter pad which spares the leather of excessive wear while a large replaceable toe slider resides on the outer-facing side. In addition to its protective properties, the outer shell is specifically engineered to provide two degrees of ventilation, depending on the wearer’s needs. A non-ventilated Supertech R boot still allows some air to get inside to keep your feet comfy while the ventilated model features die-cut perforations on top of the boot for exceptional cooling capacity. This allows wearers to choose a boot based upon the expected riding environment.
The inner-facing side of the boot is made with a large swath of synthetic suede that’s designed not to snag against the motorcycle. In fact, the entire outer shell is rather smooth and linear so that, unlike boots with lots of buckles &etc., 2011 Alpinestars Supertech R boots are less likely to catch on heel guards or other parts around the foot pegs. These unexpected grabs can be disastrous when you’re trying to grapple with a high-power superbike.
The biggest difference between the 2011 Supertech boots and that of their predecessors, is the inner Bio-mechanical ankle brace. Alpinestars Tech has chosen to use a new mesh material to further enhance wearer comfort through improved breathability and cooling performance. This highly engineered piece is designed to limit unwanted movement in a highly dynamic environment (like that of a crash situation) to reduce the risk of injury to the wearer. Working with the outer shell that’s designed to mitigate impact energy and resist abrasion, the two-part design is extremely well-adept to providing significant protection without hampering user control.
Having just been released, these boots are in limited supply. To secure a pair for yourself, call Mike at 866.931.6644 x 804 or send a note to FORUM at RIDERSDISCOUNT dot COM with 2011 ALPINESTARS SUPERTECH BOOTS in the subject line (be sure to specify your shoe size along with the color your prefer) and we’ll get back to you right away.
2011 Supertech R boots from Alpinestars.
Compared to the same model of the previous generation, there are no significant differences between the two until you look inside.
For 2011, the Bio-mechanical ankle brace has been revised with a new mesh comfort liner and laces for even better comfort and durability. The new Bio-mechanical ankle brace is seen here in the foreground.
Black on white vented Alpinestars 2011 Supertech R boots.
There’s also a non-vented version available as seen here in solid-black.
For a louder look, get ‘em in white with red.
Then there’s these black, white and yellow vented boot for anyone craving maximum attention.
If you ride a lot (and we mean, A LOT!) when the soles wear out, you can send these boots to Alpinestars’ US headquarters in California for new bottoms at a reasonable cost.
