Made precisely for the sunny-day rider,
Alpinestars Net Air motorcycle boots are engineered with premium comfort in mind. This is done via leather outers that include large swaths of abrasion-resistant mesh inserts that let feet get plenty of air. Inside, a 3D mesh internal liner surrounds each foot in a comfortable, yet reassuring manner allowing air to pass through to the wearer, the volume of which is only controlled by riding speed. The footbed uses an EVA material that’s not only anatomically-shaped, but also perforated for maximum comfort. As you can see, Alpinestars Net Air boots are especially well-adept to riders stuck in hotter climates or, those with feet that tend to sweat easily. Looking after safety, each boot includes dual-density ankle cups and reinforcements have also been applied to the toebox and heel counter. Shin plates are also armored should a foot happen to slip off the controls. And because the boots are so well-ventilated, IR-reflective inserts are employed to keep exhaust and engine heat away from your skin. For the sake of long-term durability, a TPU shifter pad is placed above the toes and the rubber sole easily withstands years or riding and walking. Thanks to a long zipper that is secreted behind the inner-facing leather flap, getting into, or out of, each boot is a simple task too.
If you’re after maximum comfort with plenty of safety, these may just be the perfect boots for you. Available in US sizes 5 - 12.5, get a pair buy calling Mike at 866.931.6644 ext 804. You can also email us with any questions you may have – send those to FORUM at RIDERSDISCOUNT dot COM with ALPINESTARS NET AIR BOOTS in the subject line and we’ll get back to you fast!
Only available in black, these boots are a perfect companion for the dedicated commuter or long distance riding where comfort is a must.
Rain or shine, a sure grip is facilitated by this specially-formulated rubber sole.
To keep repeated shifts from wearing through the boot’s leather outer shell, a tough TPU shift pad has been placed just above and behind the toebox.
As you can see, air will have no problem passing through each boot’s shell.
