Alpinestars Carver 1 and 2-piece Leather Suits - Ducati.ms - The Ultimate Ducati Forum
Old Sep 7th, 2011, 2:43 pm   #1 (permalink)
Official Platinum Sponsor
RidersDiscount's Avatar
Alpinestars’ newest leather suit comes to you in the form of the Carver model, which is available in either a one-piece or a two piece version. Fabricated entirely from high-quality cowhide that’s stitched together using Alpinestars’ advanced multiple seam construction, these suits are highly abrasion resistant to easily shrug off abrasion damage which could otherwise lead to painful injuries. Furthermore, Alpinestars’ proven CE-certified armor is positioned in all the right places: shoulders, elbows, knees and shins to provide a high degree of impact protection. These areas are further aided by PE foam pads that can be found covering the hips, coccyx, upper arms and around the torso. All this combined helps to make for a slightly softer landing if your ride doesn’t go exactly as planned.
A fully-removable liner is fitted as standard, so you can take it out, wash it and freshen the suit up as needed. This liner houses some of the aforementioned PE foam padding which helps to keep the padding exactly where they’re most useful in a crash scenario. A hollowed-out aerodynamic hump is perforated at the top, (as are areas around the chest and legs on the one-piece suit) which combined with the mesh liner, help keep you cool when the sun bears down on the road. For a perfect fit, Aramidic stretch panels are sewn into areas that are least likely to hit the ground in a fall. These stretch panels not only help with fit, but also when combined with the accordion leather stretch panels, help to free up movement that would otherwise be somewhat restrictive in an all-leather suit.
We have Alpinestars Carver leather suits available in one or two-piece configurations depending on your needs. For more information, send call Mike at 866.931.6644 x 804 or send a note to FORUM at RIDERSDISCOUNT dot COM with ALPINESTARS CARVER SUIT in the subject line and don’t be afraid to give us your dimensions and tell us what color you prefer so our experts can get you fitted correctly the first time around!
The Alpinestars Carver one-piece suit in black/white.
A large aerodynamic hump is fitted as standard on both the one and two-piece Carver suits. Notice also, the accordion stretch panel which aids in arm movement.
On the one-piece Carver suit, perforations at the sides of the torso deliver cooling air to the rider when moving down the road or track.
The two-piece carver suit in black/white.
We’ve found that flexibility is a non-issue with this suit.
As usual, Alpinestars tech’s quality of construction is second-to-none with the use of large leather panels and minimal seams. The fewer seems, the better. You can also see one of the PE foam panels that’s been sewed in just below the shoulder’s accordion stretch panel.
A three-position snap-in is available for placing your Alpinestars back protection in the suit.
Alpinestars Carver 2-piece leather suit in black/white/red. Since the jacket can be worn on its own, the two-piece Carver is an exceptional value for the street rider that does the occasional trackday.
Ask me about our specials!
Old Nov 15th, 2011, 9:12 am   #2 (permalink)
The one-piece carver suit is also available in a spiffy black/white/yellow motif as well!
The yellow makes it much easier for all and all of your adoring fans to spot you on the track.
Alpinestars GP Pro One Piece Leather Suit RidersDiscount Riders Discount 1 Oct 11th, 2010 1:49 pm
Dianese 2 piece leather suits for ladies moto Motowheels 0 Aug 8th, 2007 10:12 pm
2 piece leather suits moto Motowheels 1 Apr 18th, 2007 11:00 am
