StompGrip Tank Grip Traction Pads for Ducati Superbikes - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Aug 31st, 2011, 9:53 am   #1 (permalink)
Official Platinum Sponsor
RidersDiscount's Avatar
A favorite of street riders and racers alike, StompGrip tank pads make your life easier by reducing fatigue while at the same time, increasing rider confidence. This is done by employing a patent-pending elastomer material which gently grips your leathers to provide greater control of the bike with less effort. The elastomer material isn’t super abrasive or otherwise damaging to your leathers like grip tape can be. It’s designed to wear out and be replaced after grip levels decline – similar to tires, only these tank traction pads last a lot longer! Every Stomp Grip pad is specifically designed for each model and is held in place with a strong 3M adhesive that goes on easily and, should you need to have your tank painted, comes off clean. Clear and black versions are available for most bikes so if you have some special graphics you want to show off, go with the see-through clear version!
StompGrip traction pads are not yet available on our website. To order yours, call Mike at 866.931.6644 x 804 or send an email to FORUM at RIDERSDISCOUNT dot COM with DUCATI STOMPGRIP PADS in the subject line and be sure to include the model/year of the motorcycle you’re riding and whether you want clear or black so we can get back to you right away.
StompGrip traction pads are designed to fit on the side of your bike’s fuel tank – the area where the most grip is available for hanging off. After installation, you’ll find it takes less effort to move around and hold onto your machine.
Clear StompGrip pads for Ducati 848, 1098 and 1198.
Ask me about our specials!
Will traction pads work on plastic bit below tank? jpbelair66 Superbikes 0 Sep 20th, 2010 3:35 pm
Pics of StompGrip Tank pads on 749 Dark? RtnlSltn Superbikes 2 May 22nd, 2009 6:27 pm
Stomp Grip pads on an ST? BedMac Sport Touring 9 May 3rd, 2008 10:09 pm
Tank grip pads....advice??? AlDeJoria Supersport 7 Jun 7th, 2007 10:23 pm
knee traction pads enrico Superbikes 11 Feb 15th, 2007 8:05 pm
