ABM Brake Fluid Reservoir Kit - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!SportbikeTrackGearMotorcycle.comGraves Motorsports
Old Aug 15th, 2011, 8:53 am   #1 (permalink)
Official Platinum Sponsor
RidersDiscount's Avatar
ABM makes what is probably the slickest brake fluid reservoir kit we’ve yet to see. Each ABM brake fluid reservoir kit comes with everything you need to install and attach it to your OEM or aftermarket brake master cylinder. The 15mL fluid reservoir is machined almost entirely from aluminum and then fitted with a 90° outlet at its bottom center to ensure consistent and uninterrupted fluid transfer from the reservoir to the master cylinder. The kit also includes a special mounting bracket that can easily be bent to fit just about any custom configuration.
These fluid reservoir kits are available in gold, black or silver colors.
For more information, call Mike at 866.931.6644 x 804 or send an email to FORUM at RIDERSDISCOUNT dot COM with ABM FLUID RESERVOIR in the subject line and be sure to specify if you’d like black, gold or silver colors and we’ll be back to you right away.
Every ABM fluid reservoir kit comes complete with Norprene tubing and a customizable mounting bracket.
At the bottom center of each ABM fluid reservoir lies the outlet spigot. The spigot itself can be rotated as required so there are no kinks in kinks in the reservoir hose.
Three stainless steel bolts fasten the bendable mounting bracket to the fluid reservoir. The bracket is also slotted to allow a perfect custom fit to almost any motorcycle with no kinks in the fluid hose.
A site glass is fitted so checking fluid levels can be accomplished without removing the cap.
Choose from gold, black or silver colors.
Ask me about our specials!
LSL Brake & Clutch Fluid Reservoir Kits RidersDiscount Riders Discount 0 Jul 28th, 2011 9:13 am
Brake Fluid and Clutch Slave Cylinder Fluid Changed.. strider3 Sport Touring 1 Nov 15th, 2010 10:27 pm
WTB: M696 OEM brake & clutch fluid reservoir Curly Parts and Accessories 0 May 28th, 2010 5:01 pm
Fluid Reservoir Tubing LemmyEOD StreetFighter 3 May 12th, 2010 7:23 pm
Rear Brake Reservoir Fluid Question garryt Sport Classic 6 Aug 24th, 2008 3:02 pm
