Woodcraft 3-piece split motorcycle clip-ons are built with the racer in mind. The split fork clamp section relieves the mechanic of the (sometimes arduous) task of pulling the upper triple clamp off just to replace a single clip-on clamp. Furthermore, the modular design allows the quick replacement of only the handlebar tube should it be bent in a crash. Riders also have the ability to set the width of the controls as they please by sliding the handlebars within the clamp assembly for comfortable custom-fit controls.
Woodcraft clip-on handlebars are available to fit a wide range of fork tube diameters and we’re happy to help you get a set that fits your bike.
For more information, call TJ at 866.931.6644 ext 817 or send him an email – FORUM at RIDERSDISCOUNT dot COM with WOODCRAFT CLIP-ONS in the subject line along with the model and year of the motorcycle you’re riding, and we’ll get back to you right away.
Woodcraft 3-Piece Clip-Ons come with all the necessary hardware to install them on your motorcycle. Spare handlebar tubes are available in black or clear metal finishes. MSRP $149.99
The two-piece split fork clamp design is sculpted to be light and strong.
Four bolts hold the clamp to your bike’s fork tubes while a single bolt holds that handlebar in place.
Many OEM clip-ons include hardware for attaching a brake reservoir which goes away with the installation of aftermarket clip-ons. To that end, Woodcraft has devised this universal reservoir mount bracket which allows you to position the brake fluid tank anywhere you prefer. MSRP $19.99
