Ballistic Performance EVO2 Lightweight Motorcycle Batteries - Ducati.ms - The Ultimate Ducati Forum
Old Feb 3rd, 2011, 9:13 am   #1 (permalink)
Official Platinum Sponsor
RidersDiscount's Avatar
Riders Discount is now a stocking dealer for Ballistic Performance EVO2 aftermarket motorcycle batteries. These aren’t relabeled shrink-wrapped store-bought batteries, but instead they’re hand-made in the USA lithium iron phosphate batteries that are engineered to be extremely light, durable and powerful with every component designed specifically for use in high-performance motorcycles. If you’re looking to save a significant amount of weight, and improve your motorcycle’s starting performance, look no further than Ballistic Performance EVO2 batteries. Superbikes are designed to be as light as possible yet they still employ rather arcane lead-acid batteries that comparatively, weight a ton. Depending on the application, you can expect to save up to ten pounds of weight just by switching batteries! This is a considerable amount of mass that will be noticeably absent the first time you ride the bike with this battery installed.
From a maintenance standpoint, a conventional lead-acid battery will lose much of its charge, even during short-term storage which is why trickle chargers are so popular today. Ballistic Performance lightweight lithium iron phosphate motorcycle batteries have a very low self-discharge rate and can easily be expected to withstand indoor storage for a year or more with no recharging required to start your bike afterwards!
Another big advantage of this aftermarket motorcycle battery, other than its light weight - is its power output performance. Pound-for-pound, conventional lead-acid batteries do not transfer electricity nearly as efficiently as Ballistic Performance batteries and consequently, must be built oversized to make up for this. The result is a battery that weighs significantly more yet provides less starting power output than a Ballistic Performance motorcycle battery. And unlike some aftermarket battery manufacturers that want you to buy their expensive charging equipment, Ballistic Performance batteries come with clear instructions to fully charge EVO2 batteries in fifteen minutes with conventional battery chargers.
Nineteenth century lead-acid battery technology does not belong in your bike – step into the new millennium with an EVO2 battery by calling Mike at 866.931.6644 x 804 to order or send a message to FORUM at RIDERSDISCOUNT dot COM with BALLISTIC PERFORMANCE EVO2 BATTERIES in the subject line and we’ll get back to you right away.
Four, eight and twelve cell batteries are available to suit a wide range of applications. From dirtbikes to high-compression V-twins – if you’re unsure of your needs, call us for advice on what best suits your application.
Each EVO2 battery comes fully charged out of the box, simply plug in and you’re ready to go. The high-strength plastic chassis provides a durable package for the LiFePO4 cathode that’s up to the challenge of the starting high-compression engines. Plus its small size frees up room within your bike’s battery box for popular aftermarket tuning equipment like a Power Commander or a Bazzaz Performance tuning kit.
Smaller and lighter than your bike’s OEM battery, Ballistic Performance EVO2 batteries plug directly into your motorcycle’s OEM wire harness. No special connection hardware required. Simply plug in and ride! Best of all, unlike some manufacturers of lightweight batteries, Ballistic Performance provides the precise charging recipe in the packaging of each battery so you can quickly charge the device anytime you feel necessary.
No cheap plastic shrink wrap packaging here! Every Ballistic Performance Battery is made with a durable two-piece chassis that houses four, eight or twelve powerful cells to turn your bike’s engine over fast and reliably.
Ask me about our specials!
Old Jun 27th, 2011, 9:52 am   #2 (permalink)
Aftermarket Lightweight Motorcycle Batteries
We stocked heavy so you can ride light. Ballistic Performance LiFePO4 aftermarket motorcycle batteries are ready to ship and easy to install.
Old Oct 14th, 2011, 1:25 pm   #3 (permalink)
A big advantage we found when using Ballistic batteries is that it's much easier to install aftermarket tuning devices, like a Power Commander, in the space left over when the OEM battery is out of the equation. Take this BMW's battery tray, for example. All the space you see around used to be taken up by the heavy lead-acid unit!
Lightweight Lithium batteries Revelstoker Apparel and Accessory Chat 9 Feb 14th, 2011 4:50 pm
New Lightweight Batteries moto Motowheels 12 Jan 24th, 2011 3:09 pm
What is Ballistic Performance Components? BallisticParts Ballistic Performance Components 0 Jan 18th, 2011 8:40 am
Group buy- lightweight batteries pt 2 Antigrav HyperMotard 52 Sep 15th, 2010 12:15 am
Group buy?- lightweight batteries Antigrav HyperMotard 79 Aug 10th, 2010 6:42 am
