Cold mornings can wreak havoc on your feel at the bars when you ride off to work with your hands freezing the whole way in. Vega Drystar Gloves prevent this problem by keeping the cold out and the heat in so you can ride comfortably and safely to your destination. A Thinsulate liner acts as the main insulator which is hidden under a leather, neoprene and synthetic suede outer shell. Alpinestars standard 3rd and 4th finger bridge helps prevent painful finger roll and adds an extra layer of material along the outer side of the hands. A goatskin palm that’s reinforced with synthetic suede provides plenty of feel and extra abrasion resistance. Accordion stretch panels are used on the tops of the fingers and at the wrist so you can move about freely without your hands feeling like they’re surrounded by wet rags, even when the rain is coming down hard. Best of all, these gloves are waterproof, yet breathable with a velour interior lining that’s as comfortable as it is warm.
For more information, go to
our website or call TJ at 866.931.6644 ext 817. You can also email us with any questions you have – send those to FORUM at RIDERSDISCOUNT dot COM with ALPINESTARS VEGA GLOVES in the subject line and we’ll get back to you right away.
The Alpinestars Vega Drystar gloves come in black (shown) or black with red accents.
A carbon fiber knuckle insert provides ample impact resistance which is further aided by 4mm foam inserts on the fingers, thumb and wrist.
A large Velcro-closure gauntlet helps seal out the weather.
The inside of the glove features a complete velour liner.
Palm is a combination of synthetic suede over goatskin leather.
The synthetic suede palm extends over the outer side of each glove to protect an area that often comes into contact with the ground in a fall.
