Firstgear completely redesigned their ADV & Sport Touring pants for the Fall of 2010 and now have positioned themselves as a serious competitor against some of the top-tier European brands. Both the HT Overpants and the HT Air Overpants now have improved fit and articulation for long distance riding; they feature a touring fit as opposed to the box cut in models past. This is a vast improvement in comfort and flexibility. Depending on the riding you'll be doing and the climate in which you live, you can choose between the three-season Fall-Winter-Spring HT Overpants or the Spring-Summer-Fall HT Air Overpants.
Built on a 600D textile chassis, the HT Overpants have a built-in waterproof breathable Hypertex membrane to get you through any sort of precipitation nature has in store. Adjustable CE rated armor is found in the knees for protection along with articulation for comfort and flexibility. There is also textile reinforcement in impact areas in addition to padded hip protectors for extra protection. The HT Overpants feature pass through pockets to access the pockets of your layer underneath and two thigh air intake vents. All openings feature rubberized YKK zippers to further the waterproofing. For resistance to pipe heat and wear, there is heat-resistant material reinforcement on the inner calves. The removable liner pant is a stylish standalone
destination layer with Fiberfill insulation for warmth in the cold months.
Constructed for three-season warm weather riding, the Firstgear HT Air Overpants are a blend of 600D polyester and 250D mesh for abrasion resistance and excellent airflow in Spring-Summer-Fall riding. Like their cold weather counterpart above, they are constructed as an overpant with pass-through pockets to access your under-layer. The waterproof breathability is built-in to the zip-out liner that also acts as a standalone destination layer that can be worn off the bike. There is adjustable CE armor in the knees with hip padding for extra protection in addition to heat-resistant material on the inner calves for durability and protection. There are two front pockets for storage with a large 2/3 length side zip for easy access in and out of the pants.
Both these pants are a part of the exemplary Firstgear Fall 2010 line of product. There are several other ADV and Sport Touring pieces of gear that we'll be detailing in blogs in the future. So stay tuned.
