1995 900SS Throttling Issue - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Welcome and Introduction
Old Jan 29th, 2012, 8:57 pm   #1 (permalink)
I have a stock 900SS, 9k original miles with a throttling issue. Basically it will start and idle smoothly at 1200rpm on full choke. Reduce the choke or touch the throttle and it dies.
Carbs- Stock Mikunis, Factory Pro Ti Jet kit with upgraded E-tubes, all new seals and o-rings.
Tank- Stripped, cleaned, sealed, new sock and filter. Pump works fine.
Fuel- Fresh Shell 92 octane, plenty of flow.
Air Filter- New KN.
Timing- I checked the timing marks on the cams 2 years ago and everything was spot on. The bike has maybe 1k additional miles since then.
Any help I can get this issue resolved would be greatly appreciated!
roninduck is offline   Reply With Quote
Old Jan 31st, 2012, 8:23 pm   #2 (permalink)
I took a fuel sample, it is clear orange/yellow. Considering the issue started approximately 2 miles after I refilled I am thinking the fule may be E85 and this is causing the issue.
Any thoughts on E85 causing this issue?
900ss carb issue or maybe ignition issue park Supersport 11 Oct 4th, 2010 9:50 am
VIN issue 1995 Ducati SS/SP inlinejohn Supersport 30 Sep 1st, 2009 9:49 pm
My 1995 900SS CR Indy36 Supersport 9 Aug 3rd, 2009 9:20 am
1995 Ducati 916 Issue lochrob Superbikes 3 Mar 30th, 2008 9:36 pm
1995 900ss/sp 916WI Supersport 13 Aug 15th, 2007 8:27 am
