Oct 8th, 2011, 12:44 pm
Ducati.MS sponsor
ABM Rotor for 749-999-S4RS
ABM "Floating" Front Rotor: 749/999/S4RS
Sale Price: $247.96
List Price: $309.95
This ABM rotor uses a new proprietary blend of stainless steel, available at Spiegler only, that performs as well as iron, with all the benefits of stainless. Couple this with an all new ultra lightweight design carrier, and you have a new benchmark in motorcycle braking performance. Available now in full floating configurations, for most popular sport bikes.
Floater
Hard anodized aluminum floater, semi or full floating to allow for expansion and contraction of the rotor and carrier. This also allows for axial and radial movement of the rotor. All of this results in a better braking response by compensating for brake disc and carrier movement.
Carrier
CNC-machined, high grade aluminum, titanium anodized.
This 320mm / 5 bolt/ 15mm offset rotor will fit a 1098/1198 if you remove the caliper spacer
Weight: 3.05 lbs.
SOLD EACH.
