90 Degree Drop Forged Aluminum Angled Tire Valve Stems in various colors. The aluminum caps are included as well!
Available in:
-Black
-Red
-Silver
-Gold
-Blue
Available in both 11.3mm and 8.3mm
For our bikes and most Italian bikes you will need the 8.3mm but if you have OZ, Marchesini, Marvic and BST you will need the 8.3mm ones.
Japanese bikes and some older Italian bikes use 11.3mm's.
They are made in Italy and are the same valves which are sold under the Ariete brand.
Be aware that there has been knock-off Chinese made valve stems appearing in the market. To ensure the valve stem you are purchasing is the real deal look for the B logo stamped on the body of the valve stems.
What they do?
-Easier to check pressure and fill tires (specially on the front)
-Lighter than rubber stems- they weigh in at 12 grams each
-They are reusable, no need to replace them like rubber valves with each tire change
-Fixed to the wheel with a locking nut, can't bend, or be expelled from the wheel
-The angled quill reduces the effect of centrifugal force, which tends to fling the valve coire outwards in a concentional valve, leading to loss of pressure in tires.
Installation
Torque the locking nut to 7-10 Nm
How much?
$25 shipped for the
pair! (Shipped within USA and Canada. If you want them shipped elsewhere please PM me and I will give you the payment instructions.)
How to purchase?
Use the specific
buy now button that corresponds to the size/color of the stem you would like.
8.3mm Black - Pair
8.3mm Silver - Pair
8.3mm Gold - Pair
8.3mm Red - Pair
8.3mm Blue - Pair
11.3mm Black - Pair
11.3mm Silver - Pair
