BREMBO Superbike Narrowband 320mm X 6mm Rotor (SOLD EACH)
Sale Price: $494.06
List Price: $581.25
Brembo Part# 08.6703.11
Listing is for 1 single rotor, order 2 for a set of left & right
320mm x6mm thick. 10mm offset. 6 bolt mount.
Fits Aprilia RSV / Ducati 748, 916, 996, 998 and many other Ducati.
About the Product
Brembo developed a specific floating racing brake disc. This brake disks is designed to be used with Brembo Racing calipers.
Technical data:
- Brake disc thickness 6,0 mm
- Piston ring made from INOX, Racing material
- Brake disc inner ring billet aluminum
- Floating disc with floaters
- Race use only. Used in World Superbike and AMA
Dimensions:
- Diameter: 320 mm
- Track height: 30 mm
- Centering diameter: 64 mm
- Holes axies: 80 mm
- Hole diameter: 8,5 mm
- Holes: 6
- Off-set: 10,5 mm
- Thickness: 6 mm
