CORSE DYNAMICS Rearset Spacer
$9.95
Corse Dynamics spacer made to space your rearset away from your exhaust system. This is necessary for many rearsets when running large diameter exhaust systems.
Comes with two spacers (enough to space one side.)
CORSE DYNAMICS Ride Height Tool
$69.95
Corse Dynamics has engineered a tool for measuring ride height that works with several Ducati models
(748/916/996/998/848/1098/1198)
To accurately measure the ride height support the bike so that the rear suspension is free of load (we suggest supporting the rider pegs on jackstands), measure the ride height from our tool to a consistent reference point on the bike. Now you have a way track ride height with modifications performed on the bike.
UNLIKE OTHER TOOLS ON THE MARKET WE MADE THE FRAME INSERTS CORRECT SO NO DEBURRING IS NECESSARY TO FIT OEM FRAMES.
CORSE DYNAMICS Oil Fill Plug
$14.95
Corse Dynamics fill plugs are a great way to upgrade your Ducati with a part that is both beautiful and functional!
- Our "double hex" design allows you to remove or install these plugs with either the factory tool OR an ordinary wrench or socket.
- Our plugs incorporate a Viton O-ring to ensure proper sealing against the engine. This provides a good seal every time
- Our plug comes pre-drilled for safety wire on all six faces
CORSE DYNAMICS Lightweight Wheel Spacer
$17.95
Corse Dynamics lightweight front wheel spacer reduces .10 lbs of unsprung weight from your bike.
Replaces the factory steel spacer for the following bikes:
749 / 999 / 848 / 1098 / 1198 / Monster S4RS / Monster 1100 / Hypermotard / Streetfighter / Multistrada 1200 / Diavel / D16RR
Pictured raw but all product will be delivered in black anodized finish
Factory part weighs: .15lbs
Corse Dynamics part weighs: .05lbs
CORSE DYNAMICS Front Axle Nut
$26.95
Corse Dynamics front axle nut for the following Ducati motorcycles:
848 / 1098 / 1198 / Street Fighter / MTS1200 / Diavel
CORSE DYNAMICS 848 Steering Damper Bracket
$129.95
Corse Dynamics 848 Ohlins Damper Kit:
For use with Ohlins SD120 damper (not included) on all 848 models except EVO models.
Full billet construction anodized black, with stainless steel mounting hardware.
Requires Drilling & Tapping of the OEM Top Triple Clamp (6mm)
