DRIVEN Front Sprocket: Testastretta/ DS 1000 14T-520
Sale Price: $18.99
List Price: $29.99
OEM style 14 tooth countershaft sprocket to fit 520 chain.
Fits all TESTASTRETTA motors:
1198/1098/848/996R/998/998S/998R/749/749S/749R/999/999S/999R/S4RS /Streetfighter/MTS1200
and 2003+ Dual Spark
1000SS/ M1000/ M1100MTS/ SC1000/PS/GT1000/HM.
MW Folding Lever Set: 999/1098/S4RS/HM/SF-Black
Sale Price: $178.00 /brake and clutch set
List Price: $215.00
A multi-adjustable radial master cylinder lever set with a unique aerodynamic shape, and the folding lever gives extra protection to the brake and clutch lever. Fits all OEM style Brembo radial master cylinders on Ducati 749-999, 848-1198, S4RS, M1100, Hypermotard, Streetfighter and many Aprila.
CORSE Silicone Hose Kit: Streetfighter - Black
Sale Price: $199.95
List Price: $259.95
9 piece hose kit fits Ducati Streetfighter, Streetfighter S.
Corse High Performance Silicone Coolant Hoses are direct replacements for the OE hoses.
Improve the reliability and appearance of the cooling system. The Corse hoses are made from excellent quality reinforced multi-layer silicone to withstand high heat and pressure. These silicone hoses will resist cracking, splitting and deterioration that is common to standard rubber hoses, and will provide many miles of reliable service.
Corse Dynamics Wheel Nut Socket 1098-1198-SF-MTS1200
Sale Price: $62.95
List Price: $69.95
This tool was specifically designed to work with OEM Ducati Nuts, Billet Aftermarket Nuts, or Titanium Nuts. This is the only steel tool on the market that has been made to work with all nuts on the market.
A standard socket will not fit properly on your 1098-1198-Streetfighter and MTS 1200 wheel nut. This is because the large axle nuts on the 1098-1198-Streetfighter, have a special inner taper. This tool is designedto fit perfectly and not ruin your wheel nuts. The low profile and locator built into the socket keeps the tool from slipping off the nut when tightening and possibly damaging the nut or your wheel.
The tool is coated in an impact safe black coating. Fits 1098/1198/ Multistrada 1200/ Streetfighter OEM or aftermarket wheel nuts. 1/2 inch drive.
MW Ultimate Chain Tool (1098/1198/SF)
Sale Price: $26.05
List Price: $28.95
Easy to use single sided swingarm adjustment tool for Ducati 1098.
Made of steel for long life and industrial shop use, it's long arm makes adjustment easy, with gold zinc plate to last a lifetime.
Bottle opener incorporated into the design.
NGR Slipper Clutch w/ Plates
Sale Price: $899.99
List Price: $1,150.00
Includes aluminum friction plates and both large and small clutch hub nuts to fit all Ducati dry clutch. Designed to be used with the original OEM aluminum basket. An optional aluminum clutch basket is available for those with worn or steel OEM baskets.
The new patented design NGR slipper clutch has a very smooth positive feel on engagement and is easily adjustable for slip. It is highly recomended for racing because of its positive engagement under hard starts
COX StreetFighter Radiator & Case Guard Kit
Sale Price: $152.10
List Price: $169.00
Protect the two of the most vulnerable areas on a Ducati so you don't get stranded or find your self with huge repair bills. The 2 aluminum radiators are vulnerable from rocks and other debris kicked up from the rear tire.
The case guard will protect your aluminum cases from a broken chain. Saving you thousands in repair bills should your chain hit the case and crack it.
