Ducati 749-999 Specials - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > Site Sponsors > Vendor Specials and Group buys
Old Apr 11th, 2011, 4:47 pm   #2 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
More 749-999 specials
ATD "InvisiGARD" Paint-Saver Kit: Ducati 749/999
Sale Price: $79.95
List Price: $115.95
Our InvisiGARD paint protection film is an optically clear urethane film that is a proven product to protect your bike's vulnerable areas from paint and headlight damage caused by bug acids and road debris such as stone, gravel, sand and road asphalt.
All of our kits have been computer designed and precut - no trimming required - for your specific year and model of bike. Each kit contains all the pieces shown on the diagram, an installation squeegee as well as comprehensive easy-to-follow online installation instructions.
COX 749-999 Radiator, Oil & Chain Guard
Sale Price: $109.20
List Price: $114.95
Protect the two of the most vulnerable areas on a Ducati so you don't get stranded or find your self with huge repair bills. The aluminum radiator is vulnerable from rocks and other debris kicked up from the rear tire.
The case guard will protect your aluminum cases from a broken chain. Saving you thousands in repair bills should your chain hit the case and crack it.
BIONDI Windscreen: 749/999
Sale Price: $79.95
List Price: $99.95
Unique Double Bubble design for the entire 749-999 series. Holes are drilled to accomadate all years. Available in clear or light tint. No third parking light for a clean look. Made in Italy.
MW Billet "Showa 100mm/15mm offset" Radial Lowers: 749/999/1098
Sale Price: $799.00
List Price: $925.00
Billet radial fork mount lowers with 15mm caliper offset for Showa forks as used on the 998R / 749/ 999 / 848 / 1098 / 1198 / Hypermotard/ S4RS / M1100. Requires 15mm offset rotors. Available to fit the Brembo Radial 4 pad cast caliper, HP or Monoblock with 100mm mounts. Sold as a pair.
MW Folding Lever Set: 999/1098/S4RS/HM/SF-Black
Sale Price: $178.00
List Price: $215.00
A multi-adjustable radial master cylinder lever with a unique aerodynamic shape, and the folding lever gives extra protection to the brake and clutch lever. Fits all OEM style Brembo radial master cylinders on Ducati 749-999, 848-1198, S4RS, M1100, Hypermotard, Streetfighter and many Aprila.
moto is online now   Reply With Quote
Old Apr 26th, 2011, 5:31 pm   #3 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
MW Billet "Showa" Triple Clamp Set: 749/999 27mm offset
Sale Price: $775.00
List Price: $895.00
Performance billet triple clamp set for the 749/999 series.
These triples have a 27mm offset for better stability and include an aluminum headstock pin and hardware. Available in black only with 53/56mm diameter for Ohlins forks. No adapter is rquired.
Adjusted in the fast steering head angle (23.5), you will run the same trail as a stock bike which equals superfast turn in, lighter turn in, more feedback from the front tire and more stability out of the chassis. This allows you adjust/run the rear end of the bike lower for increased traction.
MW Billet Chain Adj. Plate: 749/999 '03-04
Sale Price: $209.00
List Price: $259.00
Ducati 749/999 Chain adjuster plate. Machined from billet aluminium.
These plates allow for mounting of spools, making it easier to put your bike up on a stand.
Available in black only.
For 2003-04 749/999 and late model 749 Dark with the cast non-braced swingarm.
NGR Slipper Clutch w/ Plates
Sale Price: $899.99
List Price: $1,150.00
Includes aluminum friction plates and both large and small clutch hub nuts to fit all Ducati dry clutch. Designed to be used with the original OEM aluminum basket. An optional aluminum clutch basket is available for those with worn or steel OEM baskets.
The new patented design NGR slipper clutch has a very smooth positive feel on engagement and is easily adjustable for slip. It is highly recomended for racing because of its positive engagement under hard starts.
Fits all Dry clutch Ducati's.
RCM Billet Clutch Cover "Open Air"
Sale Price: $119.00
List Price: $185.00
Old Apr 26th, 2011, 5:31 pm   #4 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
CF Ignition Key Cover: 749/999/SC
Sale Price: $99.95
List Price: $115.95
Carbon fiber ignition cover for 999, 749 and Sport Classic with the interactive key. This slips over the factory cover to insure functionality of the key ID interface. High quality pre-preg construction.
Polished finish
CF Key Guard: 749/999 "Large"
Sale Price: $65.95
List Price: $89.95
Pre-preg Large Carbon Fiber Key Guard. May reguire trimming on some tanks. Polished finish
CF Mono Tail: 749/999 "Desmosedici Style"
Sale Price: $399.00
List Price: $499.00
Quality pre-preg Carbon Fiber mono tail for the Ducati 749-999. It fits both mono and biposto subframes. This is a replica Desmosedici style MotoGP bike tail. Itis the only Desmosedici style tail that is made of lightweight pre-preg carbon fiber. Most other tails are made in the heavier and more brittle "wet-lay" process or fiberglass with seams. Our replica tail comes in the glossy polished carbon fiber finish but we can paint it for you before we ship. 3 way LED tailight/turnsignal kit used on our 999R is available.
CF Rear Hugger "Cast" Swingarm: 749/999
Sale Price: $109.95
List Price: $185.00
CF Rear Hugger: 749/999 03-04 Short
Sale Price: $75.00
List Price: $149.99
CF short hugger for the 749-999 2003-2004 only.
Very high quality pre-preg CF rear hugger for the 749/999 2003-2004 bikes (except 749R).
A very unique style that will stand out. Clear coated for high gloss and protection.
Made by BST.
CF OEM Exhaust Canister Cover: 749-999
Sale Price: $149.99
List Price: $199.99
CF Nose Fairing: 749/999 "Racing"
Sale Price: $299.00
List Price: $499.00
Old Apr 27th, 2011, 6:13 pm   #5 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
New Corse Dynamics parts for Ducati 749-999
CORSE DYNAMICS Oil Fill Plug
$14.95
Corse Dynamics fill plugs are a great way to upgrade your Ducati with a part that is both beautiful and functional!
  • Our "double hex" design allows you to remove or install these plugs with either the factory tool OR an ordinary wrench or socket.
  • Our plugs incorporate a Viton O-ring to ensure proper sealing against the engine. This provides a good seal every time
  • Our plug comes pre-drilled for safety wire on all six faces
CORSE DYNAMICS Lightweight Wheel Spacer
$17.95
Corse Dynamics lightweight front wheel spacer reduces .10 lbs of unsprung weight from your bike.
Replaces the factory steel spacer for the following bikes:
749 / 999 / 848 / 1098 / 1198 / Monster S4RS / Monster 1100 / Hypermotard / Streetfighter / Multistrada 1200 / Diavel / D16RR
Pictured raw but all product will be delivered in black anodized finish
Factory part weighs: .15lbs
Corse Dynamics part weighs: .05lbs
CORSE DYNAMICS Eccentric Foot Peg
$45.95
Don't let a tip over ruin your day, carry a spare.
Replacement eccentrically adjustable foot peg for Acculign,
Ducati Performance, FBF & MW rear sets in black or silver with
a 17mm diameter eccentric.
This peg has been designed to offer superior traction
while allowing great articulation for the rider!
CORSE DYNAMICS Front Axle Nut
$19.95
Corse Dynamics front axle nut for the following Ducati motorcycles:
748 / 916 / 996 / 998 / Monster / 749 / 999 / Hypermotard / Multistrada 620 / Multistrada 1000 / Multistrada 1100 / Supersport / Sport Classic
CORSE DYNAMICS Magnetic Oil Drain Plug
$18.95
Corse Dynamics oil drain plugs are a great way to upgrade your Ducati with a part that is both beautiful and functional!
  • Our plug comes pre-drilled for safety wire on all six faces. Our plugs include a rare earth magnet to collect any metal bits that might be inside your engine, our magnet is rated at six times the strength of other competing companies
  • Fits all non-testastretta motors.
CORSE DYNAMICS BST, OZ, Marchesini Rear Hard Anodized Sprocket
$74.95
The lightest 520 sprocket on the market, after hours of rigerous race testing these are now available to the public.
High quality, long-wearing 7075-T6 billet hard anodized Corse Dynamics rear sprockets are a direct bolt-on for aftermarket OZ Motorbike, Marchesini (non- OE Marchesini wheels), or BST wheels.
Available in 36 to 46 teeth in our mil-spec hard anodize bronze color
CORSE DYNAMICS Rearset Spacer
$9.95
Corse Dynamics spacer made to space your rearset away from your exhaust system. This is necessary for many rearsets when running large diameter exhaust systems.
Comes with two spacers (enough to space one side.)
Xmas Specials moto Motowheels 0 Dec 18th, 2009 5:48 pm
Stock and factory specials (DB2) Catimann Bimota 1 May 13th, 2009 6:42 am
monthly specials? mad Ducati Motorcycle Chat 1 Jan 1st, 2008 6:59 pm
