There's another thread detailing our
After Hours Sale (7pm to 9pm on 2/10), but I want to make sure people know about our BT016 package deal, too!
Bridgestone BT016 tires
120/70-17 Front
180/55-17 Rear
$199.99 Shipped!
This deal is part of the AHS, but you can pre-order (reserve) yours now:
clicky-clicky
All package-deal tires will be shipped by 2/14.
If you need a 190/50 package instead, we have an alternative for you - give us a call: 1-800-CYCLEGEAR (292-5343)
Features and Benefits
* New multi-compound technology derived from MotoGP delivers the grip performance demanded in every aspect- braking, maximum side grip in cornering, and strong traction at the exit of a corner
* Front tire features dual compound (3LC) to provide grip in all riding modes. The center compound offers linear handling while the shoulder compound secures high grip and solid contact feeling
* The front tires parallel S shaped grooves give optimal cornering force to improve stability, linear handling and absorption. Groove location across the tread center secures rich contact feeling and stable wet performance
* Rear tire features a new triple compound (5LC) The center compound offers good stability, the shoulder compound transfers power to the road with strong traction while the edge compound offers strong side grip and solid contact feeling at extreme lean angles
* The rear tires L shaped grooves enhance shock absorption and rear-end steering. Groove location not across tread center area provides both wet performance and strong traction. High speed durability is also maximized
* The steel MS-BELT (mono-spiral belt) construction applied to front and rear tires absorbs sudden impact from bumps and offers high stability and tremendous line-holding in corners
* HTSPC (High Tensile Super Penetrated Cord- Mono Spiral Belt) technology in front and rear tire provides rich contact feel, strong grip and high-speed stability
* 3D-CTDM (Comprehensive Tire Design Method) is advanced tire design technology that enables dynamic, three-dimensional simulations of tire performance at all lean angles
