Jan 2nd, 2011, 2:08 pm
Ducati.MS sponsor
DAINESE "Wave" Back Protector - $109
DAINESE "Wave 1S" Back Protector
DAINESE "Wave 11" Back Protector
DAINESE "Wave 12" Back Protector
DAINESE "Wave 13" Back Protector
Sale Price: $109.00
List Price: $179.00
WAVE is a fourth-generation back protector by D-TEC®, the culmination of a long journey that started in the 1970s with Barry Sheene and still continues today with Valentino Rossi and a whole host of great motor-racing champions. With Wave, D-TEC® has set new standards in both protection and comfort: Wave has an innovative corrugated structure with greater mechanical resistance than the previous versions, yet is exactly the same weight, plus a brand new ventilation system. The waist joint, introduced with Back Space, has been kept as it enables the protector to follow the torso’s lateral movements.
-A composite, multi-layer structure with excellent shock-absorbency properties:-1st layer: external polypropylene shield with a corrugated structure, 6 plates that overlap slightly in order to follow articulation, and ventilation holes.-2nd layer: honeycomb shock-absorber.-3rd layer: ventilated anatomic support.This three-way combination improves shock-absorbency without increasing weight.
-BREATHING CAPACITY: in contrast to previous back protectors, this model is designed for optimum air circulation along the back and for first-rate ventilation.
-ANATOMIC: the waist joint guarantees optimum freedom of movement.-The three sizes cover a range of heights for optimum back protection.-Adjustable waist-bands and elastic sweat-absorbent braces for greater comfort.
** The model (S, 11, 12, 13) varies according to the height measured in cm from waist to shoulders in order to afford sufficient back protection, while the size (M, L) varies in each according to the wearers waist.
