12-18-08 thru 01-5-09
New Product Kyle Throttle Tube.
Our new throttle tube is a one piece billet machined Black anodized 6061 Aluminum.
It is a "Snail" shape to give you more control at low throttle settings and faster movement at high throttle settings.
It is designed to work with either the stock handlebar or with or Needle bearing bars.
Or you can use it now with the stock bar and without any mods to this throttle tube convert to Needle bearings in the future.
Retail is $109.95
Introductory priced at $89.95
Brembo RCS Brake or clutch Mastercylinders $320
Brembo HP Brake Calipers 100MM C to C Billet Aluminum $1200
Akro Slip-ons $899 a set carbon mufflers.
Ohlins TTX36 DU788 rear shock $1049
Akra full system $2550 carbon or Ti mufflers.
CRG levers any color or lenght $175 for the pair
CRG rear sets $499
Kyle 22MM fork spring preload adjusters $25 a set, Blue, Red, Black, or Silver
848 STM Slipper clutches $899
Brembo Forged NON RCS 19X20 Brake mastercylinders $220
Marchesini Forged Mag 1098 wheels Only one set left. Black 17 inch $2599
Marchesini Forged Mag 1098 wheels Only one set left. Black 16.5 inch $2599
Arata Full systems $2299 848 1098 1198
Ohlins DU515 $699
Ohlins FGRT803 R and T forks $2250
Ohlins FGR800 Superbike forks with complete mount kit $9,999.00 or with FGR900 forks for $10,999
Comes with Nichols Adjustable offsett (26mm, 28mm, 30mm) triple clamps for either 1198 1098 or 848, Kyle 52 MM angle adjustable Needle bearing clip-ons, Titanium front axle, with Aluminum Nut, Fender mount to retain stock fender.
Not included are new calipers. You will need different Brake calipers as the FGR800 and FGR900 forks use a 108 MM C to C mount, stock is 100MM C to C, we have Brembo HP caliper as well as Brembo Monoblock, 4 pad and 2 pad.
Ohlins damper kit to fit the 1098 $360
http://www.shop.kyleusa.com/product....6&productId=92
Nichols Adjustable triple clamps 848 special as I have 2 in stock with some very small scratches $950
http://www.shop.kyleusa.com/product....&productId=143
Ohlins 25 MM Cartridge kit $1549 for parts only or $1649 installed. Fits Showa forks both 848 and 1098
http://www.shop.kyleusa.com/product....&productId=127
848/1098 Adjustable lenght suspension rod starts at 5MM shorter than stock rod, $105 Black or Gold
http://www.shop.kyleusa.com/product....6&productId=89
Ohlins Damper with Kyle mount kit to fit the 848 $479.00
http://www.shop.kyleusa.com/product....7&productId=91
Dan Kyle 831 394 1330 Kyle Racing
www.kyleusa.com
