KNOX Handroid Hand Armour - More than just a pair of gloves
Please click on the picture for more colors and information
Patented Exo skeletal flexible spines that cover the vulnerable knuckles, fingers and thumb and give full unrestricted movement. These link to a comfortable gel lined Metapod that covers the metacarpals and offers added protection to the back of the hand.
On the palm the tried and tested Sport Scaphoid Protection System is enhanced by additional sliding systems on all sides which ensure that in the event of an accident the majority of contact with the ground are sliders and not leather. An additional inner cuff slider works to support and enhance the SPS sliding effect. Super strong and tear resistant Kangaroo leather covers the inside palm and fingers.
The Handroid carries the most technical Knox Boa lacing system that allows precision adjustment around the whole cuff. The wrist system acts as an external brace and tightens equally from all sides. All you have to do is dial in the right torque for you. To release simply pull the dial. Putting gloves on and off has never been smarter or easier.
Click here to watch the video review
KNOX Biomech Hand Armour - More than just a pair of gloves
The Biomech is sports inspired hand armour that features an opaque knuckle protector. Soft impact absorbent honeycomb gel fills the cavity and can be seen through the opaque window on the Knuckle guard. When under pressure from a clenched fist the gel expands as it is pushed up from the inside. Superfabric, featuring ceramic beads, covers the side of the little finger.
A small metapod on the back of the hand houses the same impact absorbent honeycomb gel. The fingers give traditional protection with discreet, perfectly shaped finger mouldings. On the palm the tried and tested Sport Scaphoid Protection System is enhanced by an additional inner cuff slider which works to support the SPS sliding effect. Super strong and tear resistant Kangaroo leather covers the inside palm and fingers.
The unique Knox Boa Lacing system works to draw the side pods over the wrist with a targeted multi adjustable closure. Easily tightened, just dial in the right amount of torque for you. To release simply pull the dial.
KNOX Recon Hand Armour - More than just a pair of gloves
Classically styled but with the Knox innovative hand armour system, the Recon is aimed at the leisure touring rider. Made from the softest drum dyed aniline leather it is exceptionally comfortable.
Featuring the new opaque knuckle protector. Soft impact absorbent honeycomb gel fills the knuckle cavity and can be seen through the window on the Knuckle guard. When under pressure from a clenched fist the gel expands as it is pushed up from the inside. With the added benefit of Knox¿s low profile Scaphoid Protection System, newly designed cuff slider and discreet finger sliders, the Recon has subtle protection and designer style.
The Knox Boa lacing system works to draw the side pods over the wrist with a targeted multi adjustable closure. Easily tightened, just dial in the right amount of torque for you. To release simply pull the dial.
KNOX Zero Hand Armour - More than just a pair of gloves
Hand Armour specifically designed using high quality materials that ensure winter protection against the elements. The Zero gives comfort, warmth and waterproofing, with a superior fit. Subtly designed to give good protection in the cold weather, the finger guards are concealed under the leather and hardly visible. The important knuckle guard is covered in matt leather to give a less conspicuous styling. The Zero also includes the Low Profile Knox Scaphoid Protection System.
With the addition of the Knox Boa closure there is no more struggling with Velcro in the cold .Simply slide the cuff over your jacket and dial in. The Knox Boa closure system works to draw the side pods over the wrist with a targeted multi adjustable closure. Easily tightened, just dial in the right amount of torque for you. To release simply pull the dial
Watch the Video Review for The KNOX Zero Hand Armour.
For more information
E-Mail: Nick@Sportbiketrackgear.com
P: 888-784-4327
