Spiegler Brake Lines, DOT and TUV approved w/ Multiple Colors and Banjo's - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > Platinum Vendor Area > Sportbike Track Gear
Old Jan 11th, 2011, 10:11 am   #1 (permalink)
Official Platinum Sponsor
Spiegler Brake Lines are Sportbike Track Gear's Brake lines of choice. Brake lines are typically one of the first modification's anyone should do to their motorcycle that came with Rubber lines on it stock.
We have many video's about Spiegler lines, that show installations, brake bleeding, and just a info video on Spielger seen below.
When you order Brake lines through STG we are throwing in Free Brake Fluid and Free Brake Cleaner with an order of Front or Front and Rear Lines.
If you have any questions or would like to order a set of lines, or get a set up Custom Lines made for any application give Jason a call at 888-784-4327 ext 210, or e-mail Jason@sportbiketrackgear.com
These brake lines come DOT and TUV approved. With High quality fittings and the patented torsion system that allows you to install any line without line twist unlike other brake lines on the market that come crimped together already.
Fittings are available in green, silver, chrome, blue, black, purple, red or titanium.
Lines are available in black, clear, red blue, smoke, white, orange, green or translucent blue.
Also when you order a kit through Sportbike Track Gear, unlike most other dealers, we supply you all the banjo's needed in any color you want.
When you get your kit from us, it will look something like this. The Brake Lines you ordered in the correct length and color, with 3 banjo bolts, and 9 crush washers, as well as the tool needed to adjust the fittings for no line twist.
Nick Piccolo
Sportbiketrackgear.com
888-784-4327 ext 205
Nick@sportbiketrackgear.com
Sportbike Track Gear is offline   Reply With Quote
Old Feb 24th, 2011, 2:28 am   #2 (permalink)
Wow nice speil, and nice work with the free brake fluid and cleaner!! Just in time for my brake system rebuild too
I had a look on your site but you only have the newer Ducati models listed. I got the following part numbers off the Spiegler site. If you can get them all please let me know a price, and how much for shipping to 6018 Western Australia, Australia.
900 SS/SL 91 - 93 orig. Rear 1 S-DU0042
900 SS/SL 91 - 93 orig. Clutch 1 S-DU0043
900 SS/SL 91 - 93 orig. Front 2 S-DU0044
I'd like them all with black lines and the banjos looking like the stock colour ( titanium? ).
Thanks.
1992 900 SS
2004 CBR1000RR
2004 CBR1000RR track
JAFA is offline   Reply With Quote
Old Feb 24th, 2011, 9:02 am   #3 (permalink)
Official Sponsor
Jason@STG's Avatar
yeah of course i can get anything you need from spiegler. they're all custom cut for each order so its not a problem to get all of that stuff.
i can do $255 total on all three with shipping
Jason@STG is offline   Reply With Quote
How do you remove clutch & brake banjo bolts? John Superbikes 6 Nov 27th, 2010 11:42 pm
Banjo bolts on brake and clutch wayon Sport Classic 8 Apr 15th, 2010 1:18 pm
spiegler brake and clutch lines disgo duc HyperMotard 9 Apr 8th, 2010 8:38 am
Spiegler Brake Lines pahhhoul Supersport 9 Sep 8th, 2009 6:31 pm
Rear brake line banjo fitting alignment MontereyST3 Ducati Motorcycle Chat 3 Aug 9th, 2006 9:22 am
