Paint code requested - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By Ventodue
post #1 of 6 (permalink) Old Mar 2nd, 2016, 6:54 pm Thread Starter
Does anybody out there have the paint code for the silver color on a 1966 250 single scrambler? I have access to PPG or TCP Global paint codes. Any code for any paint manufacture will do, I think I can get them converted.
Thanks for your help.
Ricky tic
Rickytic is offline
post #2 of 6 (permalink) Old Mar 3rd, 2016, 1:20 pm
Hi Ricky,
Yes and No . Your apparently simple question has a somewhat complicated reply ...
When your bike was made, "paint codes" such as you are familiar with weren't used. Instead, each paint manufacturer named and coded his paints using his own systems.
The original paint supplier to Ducati was a company called Lechler. It's still in business today and, most graciously, they publish a list of the paints, with their names and codes, that were used at the time. In your case, it was a paint that they called "Grigio perla met" (metallic pearl grey) and which they coded as "DUC A10".
However, this name and code will obvioulsy mean nothing to a modern paint supplier!
In addition:
Paints were not supplied to the paint shop ready mixed. Instead they were supplied as components, with the actual paint being mixed on site as needed. Inevitably, this gave rise to subtle varations in tint, depending on who was doing the mixing - the yellow used on some of the late Desmo singles and the 750 Sports is noteable in this regard.
So what does all this mean?
1. You can't simply go to your local paint supplier quoting the paint code of the time. Neither can you perform a simple conversion of Lechler's code to a PPG or other equivalent.
2. If you're lucky, someone has been down this path before you, and found an equivalent modern paint. This is the case for the later wide-case Scramblers, for example.
If not:
3. You could try approaching Lechler and asking them for more info about what went into the paint. I don't know whether this works or not.
4. You can take a sample of the original paint and ask a paint supplier to match it. This is ok if you want the finished job to take into account any discolouration that might have occurred over time.
However, if you want a 'fresh out of the factory' finish, you're likely to be disappointed. Many of the paint finishes achieved by Ducati at the time were WAY better than the 'run-of-the-mill' finishes today, especially when it comes to metallized paints - such as your grey.
5. Another solution: Find a good painter, explain the situation to him, ask him to spray up some sample panels and chose whatever you find the best.
HTH
Craig
DesmoDog likes this.
Ventodue is offline
post #3 of 6 (permalink) Old Mar 3rd, 2016, 2:57 pm Thread Starter
Thanks Craig,
I understand exactly what you are saying. I guess I was looking for someone out there that has been through the matching cycle and has found a match (or closely to) the silver grey met, and has a modern up to date formula code with todays paints, for example, on my 66 Honda CL77 I found the silver color that comes real close to be a formula for 98 Mazda, (or something like that) can't remember for sure.
thanks again, for your time and input.
Ricky tic
Rickytic is offline
post #4 of 6 (permalink) Old Mar 4th, 2016, 4:28 am
I guess I was looking for someone out there that has been through the matching cycle and has found a match (or closely to) the silver grey met <snip>
One person that comes to mind is Craig Kenfield. He took a very sad-looking Monza and turned it into something very nice - and used a grey that might work for you. Go http://advrider.com/index.php?thread...ebuild.521288/ for the full story.
Craig trades under the name of DesmoDog on this Forum and will be only too willing to advise, I'm sure.
Ventodue is offline
post #5 of 6 (permalink) Old Mar 4th, 2016, 8:27 am
DesmoDog's Avatar
Thanks for the comments but the silver I chose had nothing to do with matching an original color. I used a pearl silver from House of Kolor cuz it sounded cool. I like how it turned out but it's different than the silver from the headlight that was on the bike originally. Not so much in photos maybe but in sunlight it's less metallic and more, um, iridescent? Strangely enough more "pearly".
If it were me (and I cared about stock colors), I'd follow solution 4 that Craig mentioned. Find a sample that hasn't had much sunlight on it and go from there. Even then you need someone talented though. I've heard stories of putting some sensor on it and a computer spits out a code. Yeah, right. Maybe that works on a white Celica. I had work done on my 907 and the guy got about four shades of red from different places that did that. They were all wrong and finally he did it by eye. And then told me to take it somewhere else if it needed more work.
You might also want to try posting a note on the motoscrubs.com website. It's a Ducati singles site (bikes, not potential dates) and there may be someone there who has gone through this already.
EDIT: Another solution may be taking a non-faded part to the paint supplier and paging through color chips until you find something you think matches well, in both color and "texture".
DesmoDog is offline
post #6 of 6 (permalink) Old Mar 4th, 2016, 5:50 pm Thread Starter
Thanks all for the info.
Will have to go by eye and match the best I can, did that on my Honda CL77 and it worked out real close to original.
Thanks again for the help and info.
Rickytic
Rickytic is offline
Human Verification
Hyper SP (2014) Red Paint Code? Redback911 HyperMotard 2 Feb 23rd, 2016 4:35 pm
New paint : need some idea Brizio Sport Classic 2 Feb 15th, 2016 10:16 pm
2015 DVT pannier touch up paint Fearless Multistrada 9 Jan 26th, 2016 11:48 pm
999s Error code 14.2 Koeffoet Superbikes 2 Jan 9th, 2016 1:24 am
800 ss dont save key code. lennie2000 Supersport 1 Dec 20th, 2015 12:02 pm
