Which spark plug is right? - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Dec 14th, 2011, 12:08 am   #1 (permalink)
I have a '81 Darmah. Now fitted with 5 ohm DYNA Coils.
The bike had NGK B7HS plugs in it. New plugs from BevHev are NGK BP6HS
What's the difference..?
1999 996S
1981 Darmah - long term project
1997 900SS/SP - damn near bone stock
1995 900 SS/SP - a long, long way from stock...
1992 851 Strada - almost stock
MitchB is offline   Reply With Quote
Old Dec 14th, 2011, 11:49 am   #2 (permalink)
I think it depends on how you ride; the BP7's are for hard riding and the BP6's for more gentle pursuits.
Old Dec 14th, 2011, 12:34 pm   #3 (permalink)
DesmoDog's Avatar
Part number decoder is here:
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
The difference is the BP6 has a projected insulator and a hotter heat range.
What that means to you, I'm not sure... but that's what the differences are according to NGKs site.
-Craig
Team YIKES! Motorsports
DesmoDog is offline   Reply With Quote
Old Dec 14th, 2011, 1:59 pm   #4 (permalink)
You will be fine with the BP6 plugs. The extended tip will not interfere with the piston and it will burn a little cleaner/be less prone to fouling.The colder plug will fluff up more easily in low speed riding especially if the engine is typical for an old bevel[loose valve guides,marginal voltage to coils,rich mixture,etc.] I don't think anybody really hammers their bevels enough to warrant a colder plug these days.
wdietz186 is offline   Reply With Quote
Old Dec 14th, 2011, 2:55 pm   #5 (permalink)
Well now, that's a handy little chart to have...
Thx, Craig
1999 996S
Old Dec 14th, 2011, 5:23 pm   #6 (permalink)
Passinglane's Avatar
Recently my SS fouled B7HS plugs so I stuck in an old pair of Champion L86Cs. No further problems - I've always found these plugs to work well for me. I will admit that my bike needs new valve seals which probably caused the problem in the first place since the 7s aren't hot enough to burn off the crap. B6HS plugs should work as well.
Bruce
1979 Ducati 900SS
Nova Scotia, Canada
Passinglane is offline   Reply With Quote
Old Dec 14th, 2011, 5:48 pm   #7 (permalink)
Guys, thx for the inputs.
I'll stick these new NGK BP6HS in and keep an eye on them. I'll stick the "7's" in my "Bevel Drawer"...
1999 996S
Old Dec 14th, 2011, 6:32 pm   #8 (permalink)
RockingM's Avatar
btw, for a few dollars more you might try the BPR6HIX iridium. $8 each at Advance auto or similar stores in your area. Steve also carries them.
I just put a set in my 750GT.
"Beware the lollypop of mediocrity; one lick and you suck forever. " Timothy Leary
“Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge.” EJ Potter
Robert
99 ST4 Red
1973 750 GT
RockingM is offline   Reply With Quote
Old Dec 17th, 2011, 4:46 am   #9 (permalink)
+1 on Bill's comment. I think the 6 range also helps a bit with burning off valve lubricant deposits if you use it.
Kev
machten is offline   Reply With Quote
Old Dec 17th, 2011, 11:49 am   #10 (permalink)
Well the bike fired and seems to run fine - after sitting for over two years and an unknown prior history...
Carburates fairly well. The clutch was stuck, but freed with a little coaxing. Adjusted now, so it doesn't slip.
So - I took a quick spin around the neighborhood to check shifting action. All seems OK. Handling felt very...wooden..unrefined. Back in the garage - checked pressure: 14 psi in the front / 22 in the rear... So that should help -
Major step(s) toward getting this bike back on the road.
1999 996S
best spark plug for 916 ? rockk Superbikes 10 Oct 10th, 2011 8:28 am
Spark Plug for 916 inlinejohn Superbikes 7 Feb 25th, 2011 4:17 am
Spark Plug ? on 996 stunts007 Superbikes 12 Sep 24th, 2009 8:54 pm
Spark plug gap RedDuke999 Superbikes 3 Apr 29th, 2009 9:24 pm
998 Spark Plug Gap RAin_geAR Superbikes 0 Oct 17th, 2008 11:37 am
