Lior
The Caswell recommendation is the best. Many of us have used this on our modern plastic gas tanks to try to cure the tank swelling problems that have been experienced on many new plastic tanks. I have also sealed a fiberglass tank with it. Most applications of this material on modern tanks use two separate coating applications to ensure 100% coverage inside the tank. Some people that do this as a service have jigs set up that rotate the tanks constantly while the coating cures. It is very important to follow the directions exactly and also beware of the fact that its viscosity varies considerably with temperature .... you need this as runny as possible for good coverage.
Are you in The U.S.?
61 175 TS
73 750 Sport
74 750 Sport
74 750 GT
75 750 GT
75 750 SS
02 Foggy Monster
07 SC1000SportClassic with a sealed gas tank and some mods.
93 Superlight
04 Moto Guzzi V11 Sport
Streetfighter S with some mods and a sealed gas tank.
Scheming for a 1199TriColore
"Perfection is a worthwhile goal if you don't expect to achieve it"
