75' 860 engine repair
Wrist pins are worn, but not the bushings (?) Perhaps bad heat treating?
I've been using 87mm J.E. 10:1 pistons. Bore is still good, so I'm looking for a new set of piston pins & rings. I thought I had put 88's in her but it's been about 10 years and other engines so.........
I am also replacing the tower bearings as the rear top one is bad.
Question/statement; The bevel shafts are different in that the front one is bored down the center of the length of the shaft and the rear is not. I can't seem to find any info about this. I replaced the front (bad bevel gear), as a set about 10,000 miles ago and at the time did not notice that the rear was not bored. All the bevel gears look great, so I cannot see as this has effected anything except perhaps removing a bit of weight. I remember reading years ago that the bevel engines had a problem getting the oil back to the crankcase from the heads, and racing engines actually ran an external line. Could this had been the reason for the bored shaft? Should I have the other shaft bored on a lathe, or plug the bored shaft? I am going to replace the cam bearings also while it is down. All the valves, bushings & rocker shafts are in VGC as I ported it and re-valved a while back.
While I have it down I will take a picture of the late model Monster Ignition set I installed to rid it of the original ducati stuff. It uses standared pick-ups on a nice fitted timing plate. Maybe someone would like to copy this set up. The engine really lit up when this mod was done.
Thanks...
