I needed a stand for the engine, in order to be able to work on it comfortably while sitting
Took some measurements:
I used a 30X30mm zinc profiles for the job. Cut according to a little plan I made (I'll scan it later on and post it here) and drilled the relevant holes.
Welded the whole thing
Plastic plugs were fitted
