I'm looking for some parts - Ducati.ms - The Ultimate Ducati Forum
Old Sep 4th, 2011, 8:58 pm   #1 (permalink)
MHR1000Mille's Avatar
Hi All
Ok I'm looking for some parts I know this is the wrong section but this post would only get lost in the main section amongst all the belt drives
6 bolt FPS rear wheel
6 bolt alloy disc carriers x 3
6 bolt disc x 1
left had SD/SSD side cover
PM me if you have any of them for sale or trade
have a look at my list and see if there is anything you want to trade
SS/MHR stuff
2 x SS dual seats one with lock & key seats are not torn
different side covers -alternator covers sprocket covers Tacho & bevel covers all have been polished now
CEV 177 headlight bucket to be re-chromed has now been re-chromed and than sold as a complete uint with the NOS - CEV 177 headlight insert and rim
Another complete CEV177 headlight unit to be re-chromed as well now been re-chromed
Jod Aprillia headlight insert in exl cond with re-silvered reflector
another Jod light
another Jod headlight complete but with different bucket and chrome ring
Genuine 78/79 SS rear guard being repainted at the moment Keeping
NOS 78/79 SS rear blinker mount bar
Bosch engine SS Cam supports in good condition
Genuine SS disc's 280mm front & 229mm rear and the correct rear (genuine) caliper mount for the 229mm rear disc
Borani 4 bolt disc carriers front/rear
rear 4 bolt sprocket carrier and cush drive
4 pin ign switches with keys
a set of either smiths or veglia guages
lots of re-sinked bolts washers etc etc
MHR headlight mount
SD/MHR idiot lights
SS clip-ons -used
almost new kick start shaft (internal) with zero sign of wear
SS cylinder studs genuine
cylinder head nuts genuine
SD/860
two single walled header pipes , I have to check on the numbers
SD speedo and tacho
Bosch headlight complete
SD wiring loom
SD fuel tank
a set of Bosch ign boxes
SD rear swing arm straight and repainted
SD frame
engine cases
SD chain guard repainted (mint)
SD chain guard needs small repair and paint
Genuine SSD Verlicchi clipons rechromed
used set of copied contis
860 Center stand
New 38x600mm fork tubes
32mm carbs and manifolds
GT
750GT kickstart lever 0755.07.306
750 Sports center stand straight and never repaired
Inox stamped chainguard mint
other
various internal engine parts , gear boxes 3 and 6 dog selectors etc etc
Alloy Pionoli fuel taps missing the clear bowels
many single bodied Marzocchi shocks
complete set of lower bevel gears and mounting plate
Bravettato bar/clipons
Also I have a fully worked engine that has been taken out to 92mm
all stripped down before bead blasting everything engine built by Bob Brown so I have been told
3dog new box
3.5k crank and rods
92mm Mario Sassi forged pistons
Imola cams
Imola vales and flowed heads
extra large ported intakes and manifolds to suit
42mm Malossi carbs
Note some of the parts listed I will be keeping unless I sell the 92mm big bore engine on its own as I can make a complete bike out of it
Also selling my
86 MHR Mille
and
79/80 genuine SSD
There are many other parts that I need to go through to see what else there is some I have left out for the big bore bike build to turn the engine back into a bike , FPS wheels , fairings seats side covers tank, all SS gear made to fit to a SD frame bla bla bla
Marty
Thanks Martin
SSD900
76 SS
MHR1000Mille is offline   Reply With Quote
Old Oct 16th, 2011, 8:06 pm   #2 (permalink)
Hi Marty , I am looking for a smiths speedo for my 75 ss my original speedo was mostly destroyed by a fire in my shed even a non working speedo would be ok . Thanks Robert
rfergy is offline   Reply With Quote
Old Oct 16th, 2011, 11:12 pm   #3 (permalink)
Hi Robert
The smiths set that I have I think is all but sold , to another forum member that is away this week , pending on payment they are sold will have to let you know next week some time if it sold or not
Cheers Marty
Thanks Martin
SSD900
76 SS
Old Oct 17th, 2011, 4:28 pm   #4 (permalink)
Marty,
Surely Gowie has the bits you want.
Ian
Macdesmo is offline   Reply With Quote
Old Oct 17th, 2011, 4:45 pm   #5 (permalink)
RockingM's Avatar
Hey Marty, you wouldn't happen to have a stock shifter for the 750 GT?
"Beware the lollypop of mediocrity; one lick and you suck forever. " Timothy Leary
“Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge.” EJ Potter
Robert
99 ST4 Red
1973 750 GT
RockingM is offline   Reply With Quote
Old Oct 17th, 2011, 6:37 pm   #6 (permalink)
Sorry I don't
Cheers Marty
Thanks Martin
SSD900
76 SS
Old Dec 18th, 2011, 3:55 pm   #7 (permalink)
Marty, you mention FPS wheels at the bottom of your list of available parts. I am looking for a 4 bolt rear FPS wheel for my 1979 900SS to replace a Speedline. Can you help?
Dave
Taurus is offline   Reply With Quote
Old Dec 18th, 2011, 4:50 pm   #8 (permalink)
Hi Dave
PM sent
Marty
Thanks Martin
SSD900
76 SS
Old Dec 18th, 2011, 4:56 pm   #9 (permalink)
RockingM's Avatar
Hey Marty, what about these?
"many single bodied Marzocchi shocks"
Thanks, Robert
Robert
99 ST4 Red
1973 750 GT
Old Dec 18th, 2011, 4:59 pm   #10 (permalink)
Hi Rob
What sort were you looking for ?
got any pictures
Marty
Thanks Martin
SSD900
76 SS
FOR SALE 848 1098 1198 Parts, Race Parts Ducati848 Parts and Accessories 5 Aug 2nd, 2011 8:10 pm
749R Panels & Parts (Non Carbon Fiber) 999 Parts InTeRnEt_RyAn Parts and Accessories 10 Jun 6th, 2011 9:26 pm
996 Parts(Bolts/hangers/fuel parts/Wiring) 999 parts cosmetic/front end/eng compents dv8ryan Parts and Accessories 25 Jan 22nd, 2011 8:36 am
BIMOTA PARTS ??? Problems getting parts and prices??? daotoys1 Bimota 14 Aug 19th, 2010 3:21 pm
Parting out 848 - 1098 parts - 998 parts ToxinsOut Parts and Accessories 15 May 30th, 2010 9:37 pm
