1977 Desmo 500 Lost Spark - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comSportbikeTrackGearGraves Motorsports
Graves Motorsports
Old Jul 9th, 2011, 7:15 pm   #1 (permalink)
DesmoDucks's Avatar
Unhappy 1977 Desmo 500 Lost Spark
No spark ......No key either ....I have the Red wire and gray wire connected....screw driver jumping the solenoid.....it's cranking over....Carbs are shooting gas....But no spark....I replaced the Plugs, put in a fuse, NaDa Sparka........I have a spare Solenoid should I try that? If anyone has any input that would be great ....Wiring is all original (could be that i guess).......I just wanna go for cruise around the block
1960 Bronco 125
1977 Desmo Sport 500
1980 Vespa P200E
the rest of em aren't important so i'm trading them constantly for different machines in the hopes that i'll get another DUC out of the deal
DesmoDucks is offline   Reply With Quote
Old Jul 9th, 2011, 8:18 pm   #2 (permalink)
SP3
SP3's Avatar
Images: 6
voltage at the coil + terminal?
1991 851 SP3
1966 250 Monza
1999 Moster 900 City (not so much City anymore)
SP3 is online now   Reply With Quote
Old Jul 9th, 2011, 8:25 pm   #3 (permalink)
DesmoDucks's Avatar
I got no meter.....wah wah
1960 Bronco 125
1980 Vespa P200E
Old Jul 12th, 2011, 1:43 pm   #4 (permalink)
SP3
SP3's Avatar
Images: 6
jumper wire from battery + to coil + then crank it over like you have done?
1991 851 SP3
1966 250 Monza
Old Jul 12th, 2011, 4:56 pm   #5 (permalink)
Administrator
Rainman's Avatar
Images: 15
Try this....
Wild Bill in DFW, TX
2001 900 SSie
Moderation in moderation.
Rainman is offline   Reply With Quote
Old Jul 12th, 2011, 6:57 pm   #6 (permalink)
Fiddle around with the ignition wires, you must have the wrong ones tied together. Jumping the solenoid will always turn it over, spark or not.
mizike77 is offline   Reply With Quote
Old Jul 17th, 2011, 11:45 am   #7 (permalink)
DesmoDucks's Avatar
Oh it's been Turning over fine...Just no spark....which 2 wires should be together? I thought it was the grey and red I could be wrong tho there are only 4 wires to choose....going to get a volt meter at some point
1960 Bronco 125
1980 Vespa P200E
Old Jul 17th, 2011, 11:47 am   #8 (permalink)
DesmoDucks's Avatar
Originally Posted by Rainman View Post
Try this....
I did this and man it sure cranks fast! but still no spark when i hold the plug to the head.....could be the two wires i suppose
1960 Bronco 125
1980 Vespa P200E
HELP: 1977 900 bevel twin desmo with bosch ignition running on 1 cylinder l_aysan Vintage 35 Aug 31st, 2011 6:47 pm
Dyna spark vs Stock spark, please explain? nicky k Supersport 21 Dec 12th, 2010 9:22 pm
NEW tailchop kit with original 1977 750 Sport light. lavaspit Sport Classic 7 Mar 21st, 2010 8:52 pm
Dual Spark Vs. Single Spark?? giogolf HyperMotard 10 Nov 25th, 2009 12:49 pm
1977 Kawasaki 650 help rjahr01 Ducati Motorcycle Chat 5 Aug 29th, 2006 7:46 pm
