megacycle cam - Ducati.ms - The Ultimate Ducati Forum
Old Jun 18th, 2011, 12:36 am   #1 (permalink)
Images: 4
megacycle cam
Hi, i am upgrading the cam in my 350 Narrow Case race bike to a Megacycle 564-x9. I noticed there is not a hole through the center of the camshaft out into the top bevel gears like the original camshafts, will this create lubrication issues for the top bevel gears ? I am guessing any lubrication will now come through the camshaft bearing. I have checked coil bind clearances and these are all good. The only problem is i will have to run without a valve seal, do you think this will be alright?
Terryp is offline   Reply With Quote
Old Jun 18th, 2011, 1:53 am   #2 (permalink)
No problem with the oil supply, Ducati did away with the oil hole on later bevel twins, to increase the supply to the rockers (which really need it!). As for the oil seal, you could have a recess machined inside the guide and fit an 'o' ring, as on desmo bevel twins.
Megacycle rockers back loren.betts@gmail.com Superbikes 13 Jul 24th, 2009 1:05 pm
Megacycle here I come loren.betts@gmail.com Superbikes 12 Jul 14th, 2009 11:47 am
MBP or Megacycle sell rockers or just replate? SnwMnkys Superbikes 8 Apr 1st, 2008 12:45 am
