Kickstart a single when warm - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comSportbikeTrackGearMotorcycle.com Classifieds!
Old Jun 5th, 2011, 8:09 am   #1 (permalink)
I think I'm asking this as much for others as I am for myself. There are innumerable posts asking for advice about how to kick start a single when cold, and I've figured my own technique (no choke, kick over until slight kick-back, bring it through completely and then let it come up, hit the tickler on the carb until there's a touch of fuel overflow, quarter-turn on the throttle, screw up courage and kick 'er down).
That's great when cold, but my question is, does anyone have any suggestion/alterations to this when the bike's been running for a while? Should you skip the tickler, or the throttle?
separatist is offline   Reply With Quote
Old Jun 5th, 2011, 10:04 am   #2 (permalink)
Originally Posted by separatist View Post
Should you skip the tickler ..
Yes.
... or the throttle?
May be necessary to open it just a little.
HTH
Craig
Ventodue is offline   Reply With Quote
Old Jun 5th, 2011, 9:40 pm   #3 (permalink)
I don't have a choke and use the technique you describe exactly cold or hot. I don't think my 350 would start without the tickler. If it has a half-hearted attempt to start and kicks back it can take quite a few kicks so I like to get it right first time.
2008 Ducati Hypermotard, 1970 Suzuki TC 120 sold
2005 KTM Supermoto sold, 1972 Suzuki TS250 sold
2002 KTM Supermoto sold, 1972 BSA 500 sold
1968 Ducati 350MKIII Desmo, 1978 Suzuki GS550 sold
1979 Honda XL500 stolen
remery is offline   Reply With Quote
Old Jun 6th, 2011, 12:24 pm   #4 (permalink)
I'm with you, Remery: if I don't get it fired the first time I can be there a while. I use the tickler regardless, but I find that when I do get it restarted it runs a little chunky/rich for a minute or so.
Old Jun 10th, 2011, 5:16 pm   #5 (permalink)
Hot:
No tickler. Little or no throttle. Spin it to compression. Give her a swing and just barely blip the compression release at the same time if you have one.
Cold:
Same but with the tickler.
Always starts my 450 R/T first or second kick using this method.
dgerst is offline   Reply With Quote
350 Kickstart won't return separatist Vintage 7 May 18th, 2011 3:33 am
Ducati single kickstart rubber remery Vintage 1 Sep 15th, 2010 4:48 pm
Kickstart possible? Borracho HyperMotard 23 Mar 20th, 2010 10:53 pm
Ducat Singles Kickstart Bush Duccout Vintage 3 Sep 5th, 2009 6:11 am
Theoretically could you kickstart a 848 or 1098? hawc Superbikes 22 May 30th, 2008 11:32 am
