indiana carb intake manifolds?! - Ducati.ms - The Ultimate Ducati Forum
Old May 3rd, 2011, 8:29 am   #1 (permalink)
711brett's Avatar
Hello all, i have repaired my intake manifold rubbers numerous times and will be needing to replace them soon. After twenty plus years they have seen their better days. The bike is a 1987 indiana 650 and i have been repairing the manifolds with shoo goo! (a pliable shoe repair adhesive). My question is where can i find new ones, or has anyone run across this and have a solution? I have found a company in ohio that makes the rubber itself, but mine is corved and molded to the manifold.......
711brett is offline   Reply With Quote
Old May 3rd, 2011, 11:28 am   #2 (permalink)
748girl's Avatar
Are they Bings or Dellorto's??
748girl is offline   Reply With Quote
Old May 3rd, 2011, 11:33 am   #3 (permalink)
711brett's Avatar
They are bing cv's. i'll try and post a pic or two.
Old May 3rd, 2011, 11:42 am   #4 (permalink)
748girl's Avatar
Have you tried contacting - BMW
or alternatively https://www.domiracer.com/homepage.html
Old May 3rd, 2011, 12:34 pm   #5 (permalink)
711brett's Avatar
no, but i will. thanks....
Old May 3rd, 2011, 3:48 pm   #6 (permalink)
711brett's Avatar
No luck, those only have carb parts. i need manifolds.
Old May 3rd, 2011, 4:00 pm   #7 (permalink)
711brett's Avatar
here are some picts...
indiana carb intake manifolds?!-photo198.jpg   indiana carb intake manifolds?!-photo199.jpg   indiana carb intake manifolds?!-photo201.jpg
Old May 3rd, 2011, 9:01 pm   #8 (permalink)
748girl's Avatar
If you tried ringing Domiracer and they couldn't suggest anything, then I am not sure, but....
You might give Stuart Rust at Rust Restoration in Texas a ring About Rust Restoration – Stuart Rust motorcycle mechanic and Restoration his son used to be on here and said his Dad had some spares. Otherwise he might know where you could get parts that would do.
Steve Allen at Bevelheaven does list some manifolds to suit Bing's but they suit a range of 38-40mm and I think yours are 36??? Otherwise you could ring him as well and ask.
Old May 3rd, 2011, 9:15 pm   #9 (permalink)
Those manifold sleeves should be the same as the later 750/900 belt engines.OR you could make some from radiator hose or better yet fuel filler neck hose.Try your local NAPA or other good auto parts or even tractor/industrial equipment supply store. Take a manifold or measure it so you know what I.D. hose you need. You could probably get a lifetime supply for a few bucks.
wdietz186 is offline   Reply With Quote
Old May 4th, 2011, 12:33 am   #10 (permalink)
Have you tried Ian Gowanloch? He has Indiana spares.
Split FCRs and short intake manifolds ambi Supersport 10 May 6th, 2010 9:11 pm
WTB - ST3 intake manifolds Speedmade Parts and Accessories 1 Dec 12th, 2009 5:46 pm
Aftermarket intake manifolds? RRRR Supersport 1 Oct 14th, 2008 4:34 pm
Intake manifolds macduck Ducati Motorcycle Chat 2 Feb 29th, 2008 5:27 am
95 900 ss Malossi intake manifolds??? macop1104 Supersport 1 Jul 22nd, 2007 2:36 am
