bevel single electrical disaster - Ducati.ms - The Ultimate Ducati Forum
Old Apr 14th, 2011, 11:06 pm   #1 (permalink)
Well, my 1970 single was very nice looking but continued to have electrical gremlins. As I fixed one, another popped up- due to old, corroded, and poorly connected wires. So I bit the bullet and committed to a complete rewiring.
Armed with a wiring diagram, and a bike that would actually work sporadically, I replaced each wire- one at a time. carefully labelled and leisurely checking each bit with the wiring diagram, all went smoothly. My bike has no turn signals and the horn is dysfunctional. The ignition switch has only two contacts so does not operate as a three way (on and off only). Otherwise she's stock.
So job done, I turned the key and.... nothing. No ignition, no headlight, no taillight, no brake light. Nada. I checked everything. No grounding out. All contact soldered. new inline fuse blocks replacing the old poorly grounded antlers. Everything is AWG 14 except the battery ground, which is AWG12.
Help?
I don't even know what to do next.
Thanks
Sheldon
pasophisto is offline   Reply With Quote
Old Apr 15th, 2011, 12:25 am   #2 (permalink)
If you pull the two wires from the ignition switch and connect them together, does everything work then?
Old Apr 15th, 2011, 7:41 am   #3 (permalink)
Probably not much help but on my 1968, if the battery was flat I would connect a 6V battery to one of the horn terminals and the other to ground and I could hear the "squeal" of the black box and that was enough to start it up.
2008 Ducati Hypermotard, 1970 Suzuki TC 120 sold
2005 KTM Supermoto sold, 1972 Suzuki TS250 sold
2002 KTM Supermoto sold, 1972 BSA 500 sold
1968 Ducati 350MKIII Desmo, 1978 Suzuki GS550 sold
1979 Honda XL500 stolen
remery is offline   Reply With Quote
Single Electrical Help paso996 Vintage 6 Apr 17th, 2010 7:10 am
HELP! Desmosedici RR Disaster Dallara Superbikes 71 Oct 22nd, 2008 1:57 pm
50' from disaster JAC Superbikes 9 Jul 16th, 2008 7:48 pm
Bevel single part - identify please SP3 Vintage 6 Mar 5th, 2007 1:59 pm
1098 Disaster ducati2242 Superbikes 27 Feb 10th, 2007 12:51 pm
